How do I control my sub levels through the cf mixer???
  • How do I control my sub levels through the cf mixer???
    So I have an audigy SE and want to control the sub level through the CF interface instead of opening the audigy mixer...
    how can i use this? whenever I drag up the "SUB" slider in the cf mixer it just goes right back down
    thanks!
    thanks!
    this means it is unable to find or access the SUB... Also make sure you have control rear/sub turned on in settings or it will do this.. This option is disabled by default...
    david
      david
      i turned on the controls in the settings, but how can i make it work?
        It's possible it can't pick it up on your sound card... I made some improvements in this upcoming release, hopefully it will work...
        again once you get the new release make sure to enable control rear/sub...
        david
          david
          awesome, can't wait... eta?
            hopefully couple of days at most or less, but I can't give anything for certain or I will get beat up if I miss it
            david
              david
              sounds good
                same issue with my audigy 2 zs notebook!
                its actually a weird bug because with sub control disabled, i can use the volume buttons or the slider to control my front volume.
                however, with the sub control enabled, if i try and move the sub slider, the front, rear, and sub all go to zero. if i try to use the volume buttons, they dont work. however, if i manually drag the front slider, then i can increase my volume. you may want to look into it.
                  there is another option in the upcoming release to disable/enable whether the master volume buttons in the bottom left control the rear/sub...
                  it is also disabled by default...
                  both can be enabled, but if your it is not working with your sound card then they should be disabled so no problems occur until support can be added for that sound device...
                  david
