Version 1.1?
  • Version 1.1?
    Where do I get the new version? I don't see it on the website.
    Scott
    I posted the release notes, but I haven't uploaded it yet... still double checking and testing the updater and then I will be building the MSI shortly and testing it...
    hopefully by this afternoon or tonight I will have it up...
    I will make the standard post about a new release when it's posted...
    david
      Alright, no rush. I thought I was missing something. The current version works great, and I'm anxiously awaiting the final release. FYI, the following are the two bugs I've seen. I'm sorry if they've been mentioned before.
      1) in 640x460 resolution mode, the menu drop down from the upper left doesn't look right. It has a large black banner attached to the right side. I'll get a screen shot if needed.
      2) If you set centrafuse to have the exit button prompt you for the action, the explorer shell will not load if you choose to simply exit the program. However, if I don't elect to have that prompt, it exits to windows correctly.
      Scott
        Scott
        Your #2 is already fixed and listed in the 1.1 Release Notes... I will try to reproduce your #1, it was reported... I can run 640x480 and the menu doesn't mess up...
        I will still try to reproduce... I have seen screenshots, so no need...
        david
          Originally posted by veetid View Post
          still double checking and testing the updater...
          So... are you testing the updater _within_ 1.1, or are you testing the updater in RC5 to see if it can install 1.1?
          i.e., do we get to wipe and re-install CF RC5 from scratch in order to get 1.1?
          :: Mark
            the new updater will be included in 1.1 so you will have to uninstall RC5 and install 1.1, but hopefully this updater will do everything I need it to do...
            I am still testing it, hence the delay in the 1.1 upload to the server and post on the website...
            working through one last issue and hopefully will have it up soon...
            david
              When I run centrafuse it has been saying there is 1 update available. Is this due to the work you've been doing?
                'k.
                :: Mark
                  Yes... This was due to my testing...
                  It should be gone now...
                  I have the updater fully tested and working on building the MSI and testing Phone with Zorro before I release...
                  Then it will be ready and posted to the site...
                  david
                    Can you also work out the phone auto-answering issue? Not sure if others have had that.
                      it might be fixed in the upcoming release... check out the forums at http://www.phoco.net for a lot of information about your phone... Other users might be having the same issue with just your model...
                      david
                        Any update on the update? You mentioned possibly yesterday afternoon or night, just wondering.
                        <---- Anxious
                          Patience my dear grass hopper......
                            I got the updater fully tested and I'm testing the phone now, but also waiting to hear back from Zoran for a phone test on his end...
                            it's coming soon...
                            It's built and ready to go just doing a little QA before we release to make sure no missing files or incorrect building of the installer happened...
                            david
                              lol, i just download and installed rc5 on the carpc thinking it was the new release.
                              Got to the car, drove to the shops, when i got back to my car and started it the music playlist was missing half the tracks.
                              Starting ranting to myself thinking "i thought he was ment to fix this bug".
                              Came back home and started kicking myself when i seen this post
                              http://www.deathmedia.co.uk/car/sig.jpg
