New Release, Centrafuse 1.12 (New Navigation Engine, HQCT, more)
  • New Release, Centrafuse 1.12 (New Navigation Engine, HQCT, more)
    Centrafuse 1.12 is ready for download. This version includes a new navigation engine, full HQCT support, integrated MapPoint 2006 support, and more...
    Go to the website for download information:
    http://www.fluxmedia.net/downloads
    You can view the release notes here:
    http://www.mp3car.com/vbulletin/cent...ase-notes.html
    Here is the list of remaining known issues:
    http://www.mp3car.com/vbulletin/cent...wn-issues.html
    Please test the XM resume from hibernation issue. I was not able to reproduce it, but I did improve the XM code. This might be fixed.
    david
    Thanks David!!
    Lexus IS250 CarPC Project
    Plan [++++++++++] 100%
    Buy [++++++++++] 100%
    Config [+++++++++-] 90%
    Install [++++++++++] 100%
      thank you! I pulled my carpc to do some software updates and was going to install roadrunner becuase I didnt' like the last release. This is much needed. Thanks!
        David,
        Is this meant to support incremental update? I had the pre-release 1.12 installed, and it is not recognizing the 'real' final 1.12 is available.
        Any workarounds, to avoid needing a full re-install please? Thanks!
        EDIT: Actually, the System Info screen shows that my current version is 'flagged' as 1.11. (Although it is the pre-release 1.12). So, the updater technical should work, but it doesnt. <shrug>
        2002 Honda CR-V
        Spent so far: $1105.90
        ...or even Listen to my music
          Originally posted by justintime View Post
          David,
          I had to do a full install because of the amount of changes... There was over 800 file changes/additions/differences...
          I could not build an update that large...
          There will not be another navigation engine switch for probably 2 years, so this should not happen again...
          Sorry for the trouble, but it shouldn't happen again so you can look forward to fast updates to this release and all near future ones...
          david
            btw, Nexus doesn't work anymore.
              Seriously? Damn. I will need to run a thorough XML comparison. Bummer. Someone buy me ExamXML once and for all, so I can do this properly.
              2002 Honda CR-V
                The layout changes to the nexus layout and fonts change, however, none of the main graphics don't change.
                doesn't work:
                main menu
                media player
                library browser
                radio
                dvd
                mixer
                tools
                notepad
                cfig
                works:
                settings menu
                web
                traffic
                calc
                callander
                don't know:
                XM
                Weather
                keeps onyx skin:
                ODB
                TV
                cam
                and the plugins no longer work:
                syncfs
                stopwatch
                  Don't worry I will get it fixed very quickly.
                  2002 Honda CR-V
                    I'm testin for ya', not jumping your bones - just giving ya' a list.
                      strange... There were no XML changes that I thought would affect the skin...
                      I did make a lot of changes this release so I must have overlooked something, sorry about that...
                      The plugins should work, I will test all the ones of the website to make sure...
                      david
                        Yeah, they all do except for stopwatch and syncfs. I neither show up in the settings or set buttons menus.
                        edit: I have a question,
                        what tag info does this new version use? Before it would read artist name - song title.extension. now it says: unknown artist - artist name - file name.extension
                          Ok folks, updated for compatibility with 1.12 Check my signature!
                          David: It broke the skin for a few reasons... one of them was simple: You added a weblink.png icon. Because it was not present in my skin icons folder, then CF would not load the Nexus skin properly. (removes all background images etc... it's strange).
                          2002 Honda CR-V
                            awesome thanks man!
                            Ok, another issue. I don't know if it's the software or if it's me:
                            I can't get CF to recognize my wireless network as an internet connection. It only wants to recognize dial-up networks.
                            edit, your new update doesn't put the png file in, that or I downloaded the update "too quickly" . That also fixed the filename issue as well. As well as not being able to go online with my wifi.
                            edit2:
                            Wasn't there also a nexus blue skin for odbii? Mine's still coming up with onyx
                            Back to the update though, This is much more stable than the last one. I enjoy it. Thanks!
                              How do I set up Map and Streets 2006 as navigation software? Thanks.
