Anyone recommend a good USB GPS with external antenna output?
  • Anyone recommend a good USB GPS with external antenna output?
    Hello all. I have a bluetooth GPS right now that I am using with CF, but I seem to lose connection from time to time. I am looking for a good USB antenna that I can use and bury in my glove compartment (as I have an external antenna lead terminating in there), but most USB GPS pucks I have seen do not have an external antenna connector.
    Any suggestions would be greatly appreciated!
    Via EPIA M1000
    M2-ATX Power Supply
    Win XP Pro SP2
    512 MB RAM
    60GB Hard Drive
    Xenarc 7" Touchscreen
    MP3Car Bluetooth Dongle
    Netgear USB 802.11G WiFi Dongle
    XMPC USB XM Satellite
    Well just a regular usb wired gps puck like the bu-353 can be placed in the dash behind metal and plastic, and still receive a strong signal.
    I just recently (4 days ago) bought a BU-353 and I shoved it in my dash behind metal and plastic. I got a ton of satellites and a quick lock from it. Even in my garage with the door closed I can still pick up a good signal.
    So an external antenna really isnt neccessary.
    If you are really wanting to use an external antenna, then you could get a oem chip (like from sparkfun) and connect it that way. They even have a 5hz chip to buy.
    1.9in x 2.9in -- 47mm x 73mm
      Get a SIRF4 capable unit. They will lock even indoors, sometimes. Definitely no need for an antenna unit nowadays!
      2002 Honda CR-V
      Spent so far: $1105.90
      ...or even Listen to my music
        Wow! Cool. Thanks for the info. I didn't realize the newer GPS pucks were so good.
        Via EPIA M1000
        M2-ATX Power Supply
        Win XP Pro SP2
        512 MB RAM
        60GB Hard Drive
          I have been looking and do not see any unit boasting SiRF4 capabilities. I can't even find any reference to SiRF4 on SiRF Technologies website. Are you sure you do not mean a SiRF3 compatible unit?
          Via EPIA M1000
          M2-ATX Power Supply
          Win XP Pro SP2
          512 MB RAM
          60GB Hard Drive
            I'm pretty sure he meant SiRF3, because I myself haven't seen any SiRF4 units.
            Installed
            Asus A7N8X-VM - AMD Mobile Athlon 2400
            512 Ram - 60GB HD - Opus 150w
            Lilliput 7" - Rikaline 6010
            [00000000000001100010-] 98% Completed
            Check Out My Install!!!
              You need to add your location and vehicle
              I am in NH (far away from the equator satellites, and with many trees). I have a pickup truck with a slideone camper. I can only get GPS and Satellite Radio signals when I am Southbound. Once I turn any other direction the camper blocks all the signals.
              I am looking for two GPS antennas. When the camper is installed, the one on the camper roof will be plugged in. Otherwise, the one on the truck roof would be plugged in.
              Carl in NH
                Carl in NH
                If you get just a regular SirfIII GPS receiver and stick it on the top of your camper, it will work just fine. I have used my Sirf2 GPS as far north as Thunder Bay, Ontario. By Hudson bay. Yes it is full of trees, and farther from the equator than NH.
                If you install the puck correctly, you wont have any problems.
                  Woops, my bad. Indeed I meant to say SIRF III not Sirf 4 !
                  2002 Honda CR-V
                      Originally posted by amid1978 View Post
                      1
                      2
                        very old but I thought I'd drop an answer in case someone else is searching http://inventeksys.accountsupport.co...PS_Dongle.html
