System Lockup at Centrafuse startup (BT related)
  • System Lockup at Centrafuse startup (BT related)
    Just had a fresh Xp install. Installed CF - everything worked fine.
    Added the MSI BToes (Bluetooth dongle) and when starting CF at the point where plugins starts loading, the entire system locks up!
    Already disabled al BT services, removed PhoCo from the install dir, but same result...
    Any clue what is causing this?
    I had issues with CF crashing but fixed it by using XPort3 to bridge the COM port so CF thinks it always available and connected.
    Max
