Does Centrafuse self load on windows startup?
  • Does Centrafuse self load on windows startup?
    I haven't gotten to install or test centrafuse yet.
    I'm getting the xle version and want to know do how do I get centrafuse to start up automatically when xp starts up? I already got rid of the windows starting screen. Does centrafuse autoload on default? or do I need to make some windows changes?
    You can set auto startup in settings.
      you can set the run as shell in Centrafuse if you want to replace the entire system shell, or simply just move the shortcut into the Startup folder...
      david
        david
        If centrafuse run as shell, did it starts more rapidly ?
          it should start a little faster... you can just try it and see how it works for you...
          david
            david
            Thanks for the answer.
            But If I test this option, could I return back if it's not appropriate to me without damaging Windows?
              yes, you should be able to go right back into settings, set run as shell to OFF, then reboot and Explorer will load back up...
              david
                No matter what i try i can't get centrafuse to run as shell.
                Win 7 32bit
                fitpc2
                  Same thing for me ... :-(
                    I cant get centrafuse running as a shell in win 7, used to work on xp fine, must be a win 7 thing, i have the short cut in start up folder and that boots into centrafuse pretty quick
                      True i'm sure it's a issue about compatibility with Windows 7...
                      I had to set HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\shell to explorer.exe to fix it...
                        for sure that key is not ment to be touched by a user program
                        UAC will protect that key
                        UAC off might alllow it...
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Sun, Come shine my way
                        Wind, Carry me home
                        The piece of me that died
                        Will return To live again
                          If you run CF as an Admin (Right-click and "Run as Administrator") and set the "Run as System Shell" to "On" it should work for you. It did for me, anyway...
                          After a 2 year break, I'm back! There are so many new and familiar faces here!
                          New vehicle, new ideas!
                          Chryssi - The Changeling CarPC Project
                            whats the benefit as running CF as a system shell?
                            New Car PC Build list in progress
