Speed Camera
  • Speed Camera
    Hi,
    Is there any way to add the csv file of cameras from the map monkey website into the centrafuse destinator map, to show and warn for all cameras?
    IAn
    Yes - See
    http://www.mp3car.com/vbulletin/cent...detection.html
      There's actually a way of adding speed camera warnings using just Centrafuse.
      Import the camera files as Favourites. Once there you can have them displayed on the map.
      This needs a bit of work in Destinator - basically you need to edit the favourites to show them on screen and to set the warning distances.
      Then just place a .wav file named exactly the same as your favourite in the folder \Voice\All
      (eg, if you have a favourite called Gatso, you need a Gatso.wav)
      Some useful wav files are here: http://homepage.ntlworld.com/ken.hol...C/WAVfiles.zip
      These are the ones I use - you will need to rename them depending on your favourites.
        hi,
        could you explain how is the format of the file that can be loaded? is it a .csv file? what is the record tracing?
        and exactly, what do you mean with
        and with
        thanks in advance,
        pijo
        CarPC in Progress [||||||||-] 90%
        Visit my Project
          take a look here:
          http://forums.fluxmedia.net/showthread.php?t=1916
