DVD menu
  • DVD menu
    I try plying DVD in CF ver 1.46.
    Yea Itís working fine.
    But Iím freaking out. If you like to select something in the DVD movie lower part of the screen the CF popup menu appears, and then you canít select anything.
    Is it possible or an idea to make a small transparent popup key to push for getting to whole meny?
    when in a DVD menu it should take a double click to pull up the menu, allowing you to single click DVD menu options...
    david
      Sorry David. I can see now.
      For the reference.
      So be aware, if you have single click enable the DVD menu is pulling up every time you touch the screen.
      To make the DVD work properly you have to single click set to to OFF.
      Close Thread
        For the reference.
        Close Thread
        I will fix this...
        david
          The DVD section should work the same whether singleclick is enabled or not...
          When you say DVD menu you mean the slider from the bottom of the screen right?
          whether in singleclick or not the slider will always pull up from the bottom when watching DVD video, it should detect that you are in a "DVD menu" such as the root or main title screen which all the DVD options, then i will auto switch itself to double click to pull up the Centrafuse DVD slider so you have the option to click DVD options...
          david
            Hey Dave
            Have to go for a job in Italy for a few of days. (Take a flight) But I will make a better description when I come home.
              thanks... I might not have understood correctly...
              david
