New Infill Update
  • New Infill Update
    The Infill installer has been updated with the latest code from Maxan... This update should fix the issues with it not working on the newer model G4, it will also still work with the older models...
    http://www.fluxmedia.net/downloads/CFInfill.exe
    david
    I'm still having a problem with the volume up and down on my infill. I installed Vista a while ago and tested and those buttons did work then. I reverted back to xp with a ghost copy so i had the original installed. The mute button works, and when the screen is black, and I press a volume button, centrafuse reacts and opens the main window, but the volume does not change. I can hear the Infill beep when i press the buttons too.
    I'm guessing it is some sort of software issue on my installation.
