RC1 install / audio settings
  • RC1 install / audio settings
    I had CF installed and running. I installed RC1 over it and it was working OK. I had some issues and uninstalled CR completely via add/remove programs.
    After the uninstall I rebooted and installed just RC1, when I attempt to start CF, I get an error that the program cannot be opened, sorry for the inconvenience, blah,blah,BS...
    Do I need to install the older version of CF first and then install RC1 over it?
    I'm also looking for suggestions in the settings for my speakers. If I play something through windows and the Creative Audio controllers (SB X-fi), it sounds great, however when I play through CF, it doesnt sound as good and I cannot seem to find the settings to tweak it. In the previous version of CF I was able to select my sound card under music devices (pg. 3 of the audio/video settings), when I installed the RC1 update, the box is there, but it doesnt show anything.
    Thanks in advance.
    Ok I looked at the size of the files, and by common sense reasoning, I'm assuming that I need to install 1.47 and then the update to 2.0.
    However, still stumped on the audio settings.
    Thanks.
      it should work with just the RC1 install, the logs might help with this...
      we are working through a few sound device issues...
      the next update will make it a lot easier to post your logs, as well as to get updates...
      coming soon...
      david
        Thanks for the reply. I'm going to re-install CF tonight and will see what happens there and try to get some logs.
        Thanks again!
