Sygic Drive in Centrafuse?
  • Sygic Drive in Centrafuse?
    is it possible to embedd Sygic drive into Centrafuse?
    Thread moved to the Centrafuse forum.
    This FAQ should help you: http://forums.fluxmedia.net/faq.php?...q_applications
    Jan Bennett
    Centrafuse Support
      Simple,
      * Enter Settings
      * Click the plus ( + ) button, a dialog will appear.
      * Choose Application
      * Enter Name (Sygic)
      * Choose the application location (C:\DriveXP\Drive.exe)
      * Add parameters (-s -p0x50 -r790x525) - If you using 800x600 screen | -s -r793x435 -p0x60 seems to fit nicer
      * Enter the window name. (Sygic Drive)
      If you wish to use a custom icon place it here:
      C:\Program Files\Flux Media\Centrafuse\Skins\SKIN_NAME\icons\
      or simply copy
      C:\Program Files\Flux Media\Centrafuse\Skins\SKIN_NAME\icons\gps.png
      to
      C:\Program Files\Flux Media\Centrafuse\Skins\SKIN_NAME\icons\sygic.png
      --me
        All,
        I'm working on integrating Sygic into Centrafuse properly, still got some issues that I'm working on (border when loading) but hopefully will iron it out soon.
        I have also just downloaded the Centrafuse SDK so will look at creating a plugin should it be necessary.
        I have increased the size of most images, changed all the main menu and settings menu to fit onto one screen, changed keyboard to a larger layout.
        Here is what I have come up with today.
        Loading Sygic:
        Main Screen:
        Main Menu:
        Settings Menu:
        Larger Keyboard:
        --me
          let us know when it's finished! I would love to use it!
          how do you workaround the soundsettings? when sygic gives instructions it should tur down the music, and when it's finished turn it up again. could you integrate that to?
            Notre350z wrote a patch for sygic that makes sygic mute centrafuse each time it needs to talk.
            It's quite nice if you set ATT MUTE=ON in audio/video settings of centrafuse.
            You may try, if it works for you, if not, i won't be able to help you i'm afraid...
            At least it works for me with DRIVE 7.50.225...
            Just put patch.bat, cfmm.dll and binmay.exe in you sygic directory (where drive.exe is) and double-click patch.bat
              tnx man,
              I'll try it out this weekend
                my God,
                It messed up my sygic completely and I couldnt open it upu anymore. probably doesn't work with my version of sygic I suppose!
                I'll try and find your sygic version
                  Are US maps for Sygic out already?
                  2002 Honda CR-V
                  Spent so far: $1105.90
                  ...or even Listen to my music
                    Hi...I have incorporated sygic as navigator (application), but when I send forward the audio tracks, centrafuse 1.2 screen changes, moving from screen navigation sygic to the centrafuse menu, and i'm forced to click on the button "sygic" to return to the map ... i can remove this feature ?
                    thanks...
                      Be sure to head over to the Centrafuse forums and upload your file in the downloads section. It's a great single place to keep all files related to Centrafuse.
                      http://forums.fluxmedia.net/downloads.php
                      Jan Bennett
                      Centrafuse Support
                        thanks ... but I have not added sygic as a plugin, but as external application, and I have the problem of audio tracks, when I search for songs with the buttons below the screen , sygic disappears, and switches on the main screen centrafuse ,and I have press the button sygic to return to the map ...
                          My post was directed to the indivudal who posted the file.
                          You're running Centrafuse 1.20, which isn't supported any more.
                          Chances are, the file that was written and posted in this thread is for Centrafuse 2.0.
                          I'd recomend that you update to the latest 2.0 release and then give it a go.
                          Jan Bennett
                          Centrafuse Support
                            Hi...Perhaps I explained bad, I have not used any additional files,i open software sygic through centrafuse, simply adding it as external application ....is a feature that has centrafuse, you can open any software through it ...
                              I understand that Centrafuse has that ability.
                              Thanks for clarifying that you've put Sygic in as an external application, not as a plug-in.
                              However, what I'm saying is that 1.20 is no longer supported. It's an old release and has been replaced by 2.0 completely.
                              Jan Bennett
                              Centrafuse Support
