help with shell problem
  • help with shell problem
    i just uninstalled centrafuse 1.x because i finally got around to installing v2 there was an unexpected error when uninstalling. i had centrafuse running as a system shell and now centrafuse is gone but windows does not load. only the desktop backround loads and if i try to run explorer.exe in the task manager nothing happens. any help would be appriciated
    Can you boot into Safe Mode?
    If so, you may be able to set your shell back to EXPLORER.EXE int he registry.
    If not, I don't know what to tell ya.
    How about the Wiki?
      ctrl-alt-del, run RegEdit, replace centrafuse.exe with explorer.exe in the registry for the shell application...
      HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
      then close Regedit and either reboot, or run explorer.exe again...
      just to be safe, it is best to disable shell before you uninstall...
      david
