Voice commands
  • Voice commands
    That it is necessary? What force to work? What adjust? Need to details.
    Don't understand your questions....but here a FAQ on voice: http://forums.fluxmedia.net/faq.php?..._voicecommands
    Jan Bennett
      Thanks!!!
        What programs except MS Speech Recognition Engine are necessary? I have Centrafuse 2.0.8.
          with that Voice should work, make sure to train your profile and setup your microphone, you can do this in Centrafuse settings, or in standard Control Panel, then make sure in Centrafuse Voice you have it enabled and turned on...
          david
            Thanks, David!!!
            For Windows Russian other additional programs are necessary or not?
              I think extra software will be neccesary...
              david
                Many thanks for the answer, David!!!
                Konstantin.
