Maps problem?
  • Maps problem?
    I just started to work with CF and I installed the navigation part of it and why is it that all I'm getting is Canada ? Where are the states? I did purchase CF north America....
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    are you looking in the folder? Or if in Destinator have you tried changing the map?
      i think i got it now....I have to check it when i get home from work..I will report back later on...
      CarPc
      Project "Driver"
      Planning [99.9%]
        I also have a problem with my maps in CF
        I've copied the "North American" folder into my "C:\Program Files\Flux Media\Centrafuse" directory
        and I don't see anything in my Nav
        should I copy out all the subfolders eg: USA1, USA2, USA3 etc... into the "C:\Program Files\Flux Media\Centrafuse" directory?
        thanx
          thanx
          I think you have to copy all the subfolders, so you only have to open one folder before you see all the individual files.
          Also changing the map is tricky, you have to hit the back arrow when you click setup for navigation, then click change map.
            Thanks, I'll give it a try
            If I had to do it again, I would have skipped the Centrafuse navigator
            it looks pretty crappy compared to iGuidance
