CF3 bluetooth problem
  • CF3 bluetooth problem
    Hi
    I try install new CF3 on my laptop, but when I connect my phone by bluetooth, CF3 give me an message to tell witch don't have bluetooth....
    is necessary install bluesolei? I have install bluetooth program from my Sony Vaio.
    is some one have sugestions....
    best regards
    when you installed CF, it also had an option to install BlueSoleil. you need to make sure you adapter is compatible with BlueSoleil which you can use this utility to confirm: http://www.bluesoleil.com/download/Detail.aspx?PID=9
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      hi
      I see this option and I think accept...
      I run bluesoleil check and all ok, tell who my device is supported.
      I try find in my programs and I don't find bluesoleil, I need install?
      [EDIT]
      I run CF3 setup and bluetooth stay pendent...
      I don't know why but bluesoleil stay always pendente... it stay install and after ask to restart but when I go see if it stay install don't appear anythink.
      is recomend I install bluesoleil direct?
      PS: my system is windows seven
      best regards
        make sure you uninstall the other bluetooth software before installing bluesoliel.
        VoomPC 2
          Hi
          I don't know why but my BT only work whith las version of bluesoleil, but need pay to test if it work or not.
          problem don't stay on my system, because is windows seven 64bits?
          if possible some one can put there an printscreen of this folders "C:\Program Files (x86)\Centrafuse\Centrafuse Auto\Bluetooth Plugins\Bluesoleil" to I can see what have there?
          I only have one file "cfbt.dll"
          PS: I only need bluetooth to conect my mobile phone on CF, but if is possible work with cable, don't is problem for me. is possible?
            i'm not sure if they support 64-bit for CF3, I would suggest posting on the CF forums here: http://forums.fluxmedia.net/
            VoomPC 2
