MY Centrafuse stuff
  • MY Centrafuse stuff
    trying something
    http://cid-ed9324dabf9c9cb3.skydrive...lic/Centrafuse
    i have put the UAS4 and the NEW HDRadio Radio Modules on my skydrive
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    maybe I missed something, but what's new with the HDRadio module?
    Edit: Is this only something needed to use the BoomzBox?
      its new get it... and yes it also support boozbox
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Do I need this for HD3000 with your cable?
        Nick - 08 GG Element
        Custom 3D-CAD Design, Reverse Engineering and Fabrication
          sure, need is a loose term
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            I installed the new module for CF3.0. Now HDRadio doesn't even show up as an option in Radio Settings. What files (and in which directories) am I supposed to have?
            In the RadioModules folder, there is an HDRadio folder with the two DLL files. But it just doesn't show up as an option in the radio settings. Is there some other file that I can modify?
            Edit: I put the old dlls back and it shows up in Radio Settings
              OK, re-download cf3.0
              this time its named right.
              3.1 was 3.0
              or something
              mitch
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                awesome...works now
                  id loose my mind,when doing 3 different modules at the same time
                  the all look the same to me
                  mitch
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Csfile, are you able to tune to HD stations in CF3? I cannot get them to tune. I've turned off auto right click on the touch sceen and press and hold the am/fm button and can't get the stations.
                    I've noticed there are a couple other settings on the touch panel software, wondering if I have one or more of these set wrong so that CF is not recognizing my continuous touch...although the color of the button suggests it is.
                    Jay
                      Jay
                      Yeah, for me I still have auto right click enabled. When I try to hold down the button, I just have to keep moving my finger around on the button so the right click doesn't go.
                        I just saw this thread: http://forums.fluxmedia.net/general-...ter-lists.html
                        Originally posted by S4per
                        Update: my touch screen has, what seems, 2 relevant settings for this: 'enable constant touch' and 'enable right-click'. I've turned both of them off, and so far, the responsiveness and accuracy of the scrolling list feature is at 100%. So - at least for me - seems like issue solved.
                        Maybe this may help you as well.
                          I found that if the main frequency is not an HD station, then you cannot tune to any sub stations.
                          For example, 103.3 in Dallas is an HD station. Subsequently, I can tune to the sub stations by holding down the fm key and then I can cycle through the stations.
                          However, 99.5 is not an HD station but there is an HD substation at 99.5 HD-2. Since the primary station is not HD, CF does not recognize the press and hold to cycle to other stations and does not tune in the HD-2 station.
                          Jay
