CF internet port setting?
  • CF internet port setting?
    I'm using CF 3 and just getting started, not even in car yet. I have a Wifi dongle and am trying to set the port for CF to use it. Shows up in Wifi settings and is connected and works great in window environment but in CF, nada through the Web button or email.
    Go into advanced settings and make sure you have your wifi device selected in settings. On your main menu screen, you should see a green bar at the bottom of the screen. This indicates that CF has a network connection. If the bar is gray, CF does not have a connection. CF uses the standard Microsoft Wifi settings, so if you can get it to work in windows, you should be able to get it configured in CF.
    VegasGuy
