Static on bluetooth audio? Quality adapter vs. cheapo?
  • Static on bluetooth audio? Quality adapter vs. cheapo?
    The sound quality on my calls are horrible. Static and choppy. Im currently using one of those mini bluetooth adapters that are a couple dollars on ebay. But its 2.0 and EDR compliant. Also I have no WIFI adapter so I dont think its interference.
    Would a better quality bluetooth adapter make the difference? Can someone chime in on there results and with what adapters there using. Thanks.
    1997 Acura CL (Capacitive Touch, GPS, DVD, HD Radio, Backup Camera)
    a brand name would at least give you quality components inside usually, i use msi starkey its a class 1 and i seem to have no problems with bt SNO
      Thanks sno. Ima see what deals I can find on it and try it out. Anyone else have success with any other brands?
        Got one on ebay for 14.99, i'll see if it works. I noticed on the box in the picture it has anti-interference built in, so that might be what is needed to clean up the signal.
          I think its one of the best bluetooth dongles out there, i run keyboard,mouse,obdII,phone and moto s9 headset on it never a problem. i hope you fix your problem with it. SNO
            Hooked up the msi bluetooth adapter and works perfect. Audio sounds great. Also hooked up my internal wifi adapter and have no interference.
