Centrafuse with Infill
  • Centrafuse with Infill
    I am looking to change to Centrafuse from Streetdeck on my Infill T3 (yes its still going strong)
    anyone know if the internal radio module will work with Centrafuse? Apparently there are a couple of COM dll's in the Streetdeck folder that enables the radio.
    I'm not sure if Centrafuse ever supported the T3, it was before its time, but it definitely supports the Infill G4 through a special plugin app called "Infill", so if there are any similarities (common drivers) they might work for you.
    Check out the Miscellaneous category on the CF Market - http://www.centrafuse.com/AppCategory.aspx?cid=4
    There's a plugin called Infill that controls (on the G4) the volume/mute hw buttons, tilt/brightness controls (through the software plugin) and also is required to make the AM/FM radio work. AM/FM Radio module for Infill is a different donwload. For that see the Radios section of the Market.
    Hope this helps.
    Reagan
    Formerly from Centrafuse
