Sound devices and such
  • Sound devices and such
    Alright, my setup is a bit unique to what many people are likely running. I'm using AudioMulch to do my crossover work, the problem is I need my default audio output to be through Virtual Audio Cable, but my volume control doesn't work through VAC, it works through a device called M-Audio Multichannel. So is there any way in a config file or something to set volume control to control a different device then what it's outputting through?
    Hah nevermind! I just figured out that in VAC there is a check box for volume control which enables volume to be controlled through the VAC device. Stupid me
      Ok, another issue though is that Centrafuse suddenly only wants to use one channel of audio? It was using 2 before....and everything else works just fine it's only Centrafuse? Hmm....
