Bluetooth Phone connection solved
  • Bluetooth Phone connection solved
    After a couple of dongles and head banging this worked for me!
    just passing on the good word:
    http://www.youtube.com/watch?v=vvAkw...LPBvQunPPtQQs=
    Nice, too bad the auction is ended and he has not posted it again.
    I really hate that sometimes my BT works, and sometimes not. Mostly it just won't connect automatically, when every other BT device I have ever owned has always connected find every single time.
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
      It is there, I just checked
        The guy just re-listed it- It was expired when I searched.
        Thanks for the heads up-
          I wanted to offer another solution. After spending hours trying to figure out why CF would not save the default phone, and going through 3 dongles, I solved it.
          I went into the Application Data for CF and deleted the bluetooth.xml file. Now CF saves the default.
          Hope that help someone.
          Sent from my PG86100 using Tapatalk 2
            Very good suggestion- if/when it happens again, I'll check that. I did re-load CF, and that fixed my problem. (I made no changes to the BlueSoleil).
            I did buy the above BT stick- it acts exactly the same as my old one. Works sometimes, not other times. It's nice when it works, but may it is annoying to have to unlock my iPhone and hit three buttons to tell it to connect every time I get in the car.
            I've got 4-5 other BT items, and not a one of them has ever had problems pairing with any other device or phone. It's really annoying that we can't buy something for Windows that can work as reliably.
