Framework error
  • Framework error
    Hoi everybody ,
    I still have this framework errors ;
    Wath i did;
    removed framework 3.5 and installed again. inc net 2.0 and 3.0
    switched out framework 4.5 and switched on again. c'ant install dotnet 4.0 full because there is already a higher version on the pc .
    removed sql server 3.5 compact and installed again. version. sp2
    removed centrafuse completly , also the maps in program files and program data , and installed again , first version 4.0.26.110 and then updated to 4.3.6. the problem starts here with cf 4.3.6.
    The O.S. is Windows 8 pro ,bought it at the microsoft store ,and i keep on getting these framework errors ,so it is not working as it should ,on win 8.
    Here is the cf logfile;
    30-12-2012 08:48:48 (48:48.12)
    De objectverwijzing is niet op een exemplaar van een object ingesteld.
    bij eGNMUbjd5FGCDKl7IuI.eShU6QjNtHhgx053ha8.CF_Main_vr Command(String , String )
    30-12-2012 08:54:08 (54:08.15)
    De index ligt buiten de matrixgrenzen.
    bij eGNMUbjd5FGCDKl7IuI.eShU6QjNtHhgx053ha8.evYb0od34O ()
    30-12-2012 08:54:47 (54:47.56)
    30-12-2012 08:57:21 (57:21.06)
    System.NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.
    bij WoWeather.WoWeather.RGrnU9z62go1bEarBS(Object )
    bij WoWeather.WoWeather.y1J9eXmpf()
    30-12-2012 08:57:29 (57:29.38)
    30-12-2012 08:57:35 (57:35.48)
    bij WoWeather.WoWeather.taVBfS4yA()
    30-12-2012 09:04:56 (04:56.00)
    I'm searching now ,for almost 2 weeks ,but no succes ,get no support from centrafuse also ,
    help ,help please.
    the startup of Windows 8 is very quick , i like it ,but i think i have to search for another frontend program ,because this sucks.
    lovely greetings
    Pajoghi.
