What's new over at Centrafuse? A LOT!
  • What's new over at Centrafuse? A LOT!
    Hi gang! I don't post over here as often as I should to let the fine folks at mp3Car know what's going on at Centrafuse. I'll try to fix that moving forward.
    There's a new Centrafuse (4.4.1) build out and we're pretty pleased. Here's a quick list of the improvements:
    1. Compete installer contains and checks for all pre-requisites. Installs any that are needed before installing Centrafuse. You don't have to be connected to the internet to use this installer...it's big (330mb) and complete.
    2. Automatic Updates. Centrafuse now contains an automated updater that periodically checks for new versions of the Centrafuse core, and will automatically download and install them with your permission.
    3. Lots of minor bug fixes and performance updates.
    Big news on the navigation front. JohnJore has just about completed integration of PC Navigator with Centrafuse. This provides full audio event control, full CFNavInfo data, and full integration with CentrafuseConnect. Search for POIs and addresses using Google Maps and save them to your account on CentrafuseConnect. When you need them, download them directly to Centrafuse in your car and route them using Navigator. Best of all....it's all free! PC Navigator (free edition) comes with open StreetMaps. The Centrafuse app is free, as is the CentrafuseConnect app and web account.
    That "free" thing is pretty popular around here, so let's keep going.
    Want a full-featured DVR capability for your Centrafuse installation? You got it. DashCam1 and 2 are now available for testing. They're identical and allow you to use two cameras at once. Date/Time and GPS data is overlaid on the recording. Manual and automatic DVR recordings are supported, along with snapshots. Too much to cover here, but head over to the Centrafuse forums for details. Did I mention free?
    How about some HD music? The Shoutcast app has been updated for Windows 7/8 users (.NET 4.5 Framework required). Some real nice 320kbps stations to be found (if you have the data plan to support it).
    Click image for larger version
    Maybe Pandora is more your style? No problem, we have that too. Again, Win7/8 users only.
    We've got 2 (count' em) DAB/DAB+ apps in the market ready for you guys outside the US.
    And so much more. Head on over to www.centrafuse.com or forums.centrafuse.com for all the details.
    Cheers!
    Just posted an update for Centrafuse, to version 4.4.2
    This update can be downloaded and installed by pressing the "update" button in settings. Just follow the onscreen directions and you're all set.
    The update fixes some missing pieces in the Market app, re-enables in-place app updates and now notifies you when an installed app has an updated version available. So The Centrafuse core, and all of the available Market apps with notify you when an update is available and you can compete the update directly from the Centrafuse interface.
    Enjoy!
      Centra fuse is now fully free?
      CarPc
      Project "Driver"
      Planning [99.9%]
      Parts Collected [98.5%]
      Installation & Fabrication [98%]
      Total Completion Level [96.9 %]
      http://www.mp3car.com/vbulletin/work...ct-driver.html
        No, but keep an eye open for our "Black Friday" promotion where you can get Centrafuse for 10% off! Just $62.99 for all the good stuff.
        Cheers!
          Centrafuse is worth it imo. Been using it for 5 years or so!! Can't wait to see what's new!
            Cheers!
            Can you fix the D/L from your site?? It takes 9-10 hours for a 350 meg file. It is crazy. It's like the dial up days
              So as you can see, I'm not the only one having issues downloading CF...something is wrong on the CF end. My routers and modems are working as designed. Maybe you can upload it some where else so we can get to download it. After all I did pay for it..
              CarPc
              Project "Driver"
              Planning [99.9%]
                Trading anecdotal evidence isn't going to be of much help. So let's do some debugging.
                Open a command prompt and type the following (without the quotes):
                1. "ping www.centrafuse.com" and record the response time.
                2. "tracert www.centrafuse.com" and look for unusually long response times and where the trace dies.
                3. "nslookup www.centrafuse.com" and see where it resolves the IP address.
                That will get us started.
                  if this helps, here's what I get when I ping Google then Centrafuse:
                    I just turned the response on for the router. Try it now.
                      Working now, I have no idea if these number s are good or bad but there they are:
                        So here's what I get from the other side of Las Vegas... 25 miles from my server.
                        As you can see, the numbers for Google and Centrafuse are nearly identical (Centrafuse is actually just slightly better). Now on your screencap, the Centrafuse number are more than 10X worse than Google. So part of the problem lies outside of the Las Vegas metro interconnect area. But more specifically, it is outside of anything I have control over.
                        I'm totally just guessing, but if I were to point a finger, I'd point at Network Solutions which provides the DNS for Centrafuse.com. They suck giant #$%#$%#% ever since web.com bought them out.
                          I ran the pings and traces. I'm in NYC. All seems normal. But still downloading takes 5 hours. Thanks again for the drop box link. That took only about 5 mins to download.
                          CarPc
                          Project "Driver"
                          Planning [99.9%]
                            PING www.centrafuse.com (24.120.12.171): 56 data bytes
                            64 bytes from 24.120.12.171: icmp_seq=0 ttl=51 time=102.397 ms
                            64 bytes from 24.120.12.171: icmp_seq=1 ttl=51 time=106.679 ms
                            64 bytes from 24.120.12.171: icmp_seq=2 ttl=51 time=103.305 ms
                            64 bytes from 24.120.12.171: icmp_seq=3 ttl=51 time=102.710 ms
                            64 bytes from 24.120.12.171: icmp_seq=4 ttl=51 time=104.722 ms
                            --- www.centrafuse.com ping statistics ---
                            5 packets transmitted, 5 packets received, 0.0% packet loss
                            Traceroute has started…
                            traceroute to www.centrafuse.com (24.120.12.171), 64 hops max, 72 byte packets
                            1 192.168.0.1 (192.168.0.1) 18.588 ms 5.361 ms 3.089 ms
                            2 cpe-142-105-32-1.nyc.res.rr.com (142.105.32.1) 34.526 ms 30.866 ms 29.066 ms
                            3 tenge-0-2-1-2.nycmnyo-rtr1.nyc.rr.com (24.168.135.81) 12.166 ms 12.405 ms 11.999 ms
                            4 agg31.nyquny9101r.nyc.rr.com (184.152.112.85) 15.887 ms 18.190 ms 12.693 ms
                            5 ae-3-0.cr0.nyc20.tbone.rr.com (66.109.6.76) 16.218 ms 19.023 ms 14.677 ms
                            6 107.14.17.218 (107.14.17.218) 22.713 ms 13.815 ms 11.741 ms
                            7 ip70-167-150-232.at.at.cox.net (70.167.150.232) 16.121 ms 14.446 ms 13.511 ms
                            8 nwstdsrj02-ae2.0.rd.lv.cox.net (68.1.0.91) 98.595 ms 99.951 ms 98.346 ms
                            9 24-234-6-249.ptp.lvcm.net (24.234.6.249) 99.974 ms 99.453 ms 97.183 ms
                            10 24-234-16-26.ptp.lvcm.net (24.234.16.26) 91.228 ms 92.752 ms 91.623 ms
                            11 24-234-16-26.ptp.lvcm.net (24.234.16.26) 94.920 ms
                            24-234-16-30.ptp.lvcm.net (24.234.16.30) 90.972 ms 94.513 ms
                            12 mail.centrafuse.com (24.120.12.171) 102.039 ms 102.533 ms 101.371 ms
                            this is from a MAC
                            CarPc
                            Project "Driver"
                            Planning [99.9%]
