destinator and centrifuse
  • destinator and centrifuse
    Has anybody gotten this to work? I've used the proper window name with now success.
    It works with the D3 frontend, but haven't heard of anything else. Which version of Destinator are you trying to run?
    david
      I've found when you exit/quit on the monkey front end it doesn't quit the GPS app correctly task manager states it is still running and cantrafuse won't load it again till shutdown and restarted.
        Ya. I'm using D3 Frontend. I tried 1.1.2 and 1.1.3.
        Is there any logging going on? I don't see a log file. Can it be turned on?
          Here's the screenshot of the result of clicking on GPS on the main window.
            Before I start to embed Destinator3, I would like to ask if anybody already has developped Dest3.1 skin that matches Centrafuse?
              The default skin isn't too far off.
                my problem is that it embeds right, but it wont display motion, the map just sits in one spot it wont refresh untill hit a button like the menu button. then it will quickly update and display the menu.
                CarPuter ProgressO meterO
                [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
                visit me on the web at
                http://gozips.uakron.edu/~cmk23/
                  I haven't finished the logging yet, but it will be in the next version... I will try and get a copy of D3 so I can test... So far I have only used it with Routis, iGuidance, Mappoint, Street Atlas and I didn't experience any of these problems...
                  Not sure about the embed problems.. There are a few other people that seem to not be having any problems... Try and ask them what they did...
                  david
                    Works fine for me!
                    Destinator 3 For PC! - http://www.map-monkey.co.uk/
                      A little more detail please ninja monkey. Or anyone else. What version of D3 Frontend are you using? Which file did you point Centrafuse to and what window name did you give it?
                        @ ninja money have you tried exiting the desintantor and reloading it? Does that work ok?
                        @veetie deleting the config file helped with "the can't play file type" error. Thr first time I rqan setup I choose the incorrect folder, I then change it and I think this messed up the config file.
                          bertybasset: If you exit Destinator inside centrafuse, it will not reload it again... This is by design, currently... Basically the first time you launch GPS it runs the specified program and embeds it... It assume you won't ever close it... CENTRAFUSE will automatically close out your specified application when it exits... I am probably going to add a check everytime the button is clicked to make sure the app is loaded and if not attempt to load and embed it again... Originally I planned on being able to remove the top file menu of applications also, which meant you really wouldn't have been able to exit from most apps once embedded, so I didn't need it to re-check...
                          Currently if you change your music path in setup you have to go clear out your current playlist and re-load songs in order for the path to be corrected and stop getting the unable to play file... I think you will have to also open up your playlists and change the path also, which I should probably do in the app, but just realized it
                          david
                            correct about that unless you have always show on top enabled in setting. I've just noticed that desinator is always loaded behind the top centrafuse windows.
                            When always show on top is disabled the program works as expected.
                            Looks like a bug a design feature.
                              so when "always ontop" is enabled it doesn't embed the application?
                              david
