unable to play
  • unable to play
    ok, i was testing this software out, but for some reason when i click an mp3 to play, it says unable to Play along the top?
    any ideas, do i need a specific player installed?
    I wish i knew how to do fiberglass work...
    You need managed directx.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      try deleting the config.xml file this will cuase setup to be re-run and it will fix the problem., did for me.
        Had your proble, solved it with 0l33l solution...
        Renault Megane...the OEM look
