on screen keyboard
  • on screen keyboard
    it whould be nice having an on screen keyboard available when I need to input a destination on my gps, how you guys fill the text box in the gps application?
    p.s. I use MapSonic , don't know if other GPS sw has an embedded osk, in case let me know
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    dunno bout mapsonic, but destinator, copilot, and routis/iguidance all have osk's.
      wow
      gonna change gps software
      thank you
      Peugeot 206 1.4 HDi
      Celeron 1.2ghz
      256mb DDR-2 533
      80gig 3.5" SATA HDD
      M2-ATX
      8" Lilliput TS LCD
        Windows XP On-Screen Keyboard
        There's always the built-in OSK that comes with Windows XP.
        Go to the Start Menu, All Programs, Accessories, Accessability, and On-Screen Keyboard.
        It's pretty basic, but allows you to enter pretty much any text into any windows program.
        It'll run in the foreground with the program active in the background, so you just hit the keys to type.
          Is there a way to make the WinXP OSK bigger?
          Here it is! My carputer install! 1997 BMW M3
            yes but I don't wont to have it always on top and in a touchscreen enviroment how am I supposed to lauch/hide it when I need? I was thinking about a small telephone-like keyboard with three letters for each button
            Peugeot 206 1.4 HDi
            Celeron 1.2ghz
            256mb DDR-2 533
            80gig 3.5" SATA HDD
            M2-ATX
            8" Lilliput TS LCD
              have it run minimized at start up and sit on the task bar until you need it.
                I made a small Alt-Tabbing application that would help with that.
                http://www.mp3car.com/vbulletin/showthread.php?t=38823
                Hope that helps.
                Installed.
                -GPSSecure- - GPS Tracking
                  Thank you, just tried the program
                  I've got a problem, when I switch between the screens of centrafuse alttabber goes to background and I can't see the square
                  another problem, seems to me that the trasparency doesn't work, if I set 0 the button neither appear not function, if I set 0.1 it is the same as 0.9
                  I'd like to make it totally hidden, maybe even when I click on it
                  Peugeot 206 1.4 HDi
                  Celeron 1.2ghz
                  256mb DDR-2 533
                  80gig 3.5" SATA HDD
                  M2-ATX
                  8" Lilliput TS LCD
                    Do you have the .NET Framework installed on your computer? Just tested it out again and it seems to work fine. That did make me aware of one problem though. It turns out that the opacity levels have to be between .01 and 1.00. Not 0.00 and 1.00 like I originally said. If you set the opacity to .01 it will be completely invisible.
                    I'll test it out with centrifuse today. Oh and FYI, if you change the opacity after AltTabber is already open it won't change. AltTabber loads in the opacity level at startup. So that may be the reason why you didn't see a differance between .1 and .9. Try closing the program in between changing levels.
                    Installed.
                      Yes I have framework installed, it is necessary to run centrafuse
                      I found the way to make it always on top but the ppacity problem stays, I can't see any differences between 0.01 and 0.9, in eacy way the box is grayed
                      Peugeot 206 1.4 HDi
                      Celeron 1.2ghz
                      256mb DDR-2 533
                      80gig 3.5" SATA HDD
                      M2-ATX
                      8" Lilliput TS LCD
