Centrafuse and Vob files
  • Centrafuse and Vob files
    Not sure if this has been asked or discussed, I couldn't find anything.
    Does Centrafuse play vob files? I have my movies in separate directories such as.
    c:\movies\movie1\video_ts
    c:\movies\movie2\video_ts
    etc...
    I also have DivX files which I can play in Centrafuse.
    Currently I get it to play my DivX files but I can only have it display one movie at a time. In order to display a different movie I go back into settings and change the default directory to a different movie.
    Is there any way of just pointing Centrafuse to C:\movies and have it lookinto my subfolders for the movies? Currently my home HTPC application works like this. It pulls the movie name from the directory name and displays the cover.
    BTW: I received my Xenarc 700TSV-B tonight. I currently have Centrafuse running in 800x600 which I find acceptable for testing purposes anyhow. Can't wait for the next release.
    Thanks,
    Chuck
    Any plan for this?
    Thanks,
    Chuck
      chuckster: you can build video playlists, so you can select and add all your videos to a playlist and then load it.. It will then play them without having to go back to the video manager.... My video player might play vob's, but I am not sure... Just add vob as a valid video extension in the "config.xml" file in the system folder. Then go to the video manager and see if a vob will play... If so, for now, you can add all the vob's to a playlist and play them through...
      I look into better support for dvd folders...
      david
