CENTRAFUSE Update 1.11
  • CENTRAFUSE Update 1.11
    Major speed improvements.... Once everything is loaded, screens switch instantly on my M10000... Also I got rid of all the redraw problems, except still working on the video/dvd... The "enhanced graphics" option in setup doesn't do anything anymore, not neccesary.
    I also fixed the weather temps being switched, the dvd volume buttons drawing improperly, and the problem with occasional messed up buttons on the bottom nav during the initial load...
    Download here:
    http://www.fluxmedia.net/downloads/cf-beta1.11.zip
    This is just a binary update and only includes the centrafuse.exe. Just overwrite your current centrafuse.exe with this one.
    david
    When I am on the weather screen and tab to another app and tab back, I get this.
    Also, is it supposed to start at the music screen and not the home screen?
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Check the option in your settings.... Is auto launch music enabled or disabled? Try toggling it and re-writing your XML...
      david
        david
        That fixed it... thanks
        BUT, if I got to the music manager, and to the albums and find an album that has album art, and the next one doesn't, the album pic doesn't disappear.
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          0l33l: I fixed it and updated the link above...
          david
            david
            Yes, its fixed
            About the first drawing error. I noticed that it happens when I tab into CF. If I click on the task bar then everything is ok, but if I alt-tab I get that drawing anomaly.
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              0l33l: Is the drawing problem only when tabbing back to the weather screen? What about on other screens?
              david
                has the destinator bug been fixed . i.e not refreshing the map ?
                Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
                The car
                  david
                  This is the other screen I found it on. I do get a small artifact on the music selector as you could see in one of the other pics.
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    I've got another drawing problem, when I go to GPS with my embedder application, when I switch back to radio or mp3 I can se both the radio stations and the mp3 controls on the buttons bar. I think the picture explains it
                    don't bother for the embedding problem, I have it only on one pc and I suspect it's an "on top" problem or something like this. on the other pc I've no problems with embedded apps
                    another thing, the program starst on the main menu, but if I switch to radio and then back to main menu it redraws this (the first time)
                    Peugeot 206 1.4 HDi
                    Intel Mini-ITX Mainboard
                    Celeron 1.2ghz
                    256mb DDR-2 533
                    80gig 3.5" SATA HDD
                    Sb Live 5.1 w/ KXProject Drivers
                    M2-ATX
                    8" Lilliput TS LCD
                    100% installed and working :D
                      When a music directory defined in options don't exist Centrafuse won't start. Doesn't give you any message on why it won't start. Just a standard JIT general debugging message. (Earlier I was testing with a DVD-R with mp3's. Had removed it and forgot. Took me quite a while to figure out why CF wouldn't start since I just got the debugging message. OK, a bit tired too I guess...)
                        works great only thing is that the buttons on the Video and DVD screens still get 'build up' every time, not only the first time (this is on a 2.8 ghz p4 laptop)
                        my destinator map resource down permanently
                          I can't get a DVD video to play, what codec/software do I need to install in addition to centrafuse, this a is brand new PC I just built.
                          Cheers,
                          Grant
                          '03 Corvette Z06 - car pc soon
                          '99 Eclipse GSX
                          '03 Ducati Monster
                            you need mpeg2 video/audio codecs, try wmp9 or 10
                            or installa a dvd playback software like powerdvd/windvd/cineplayer
                            Peugeot 206 1.4 HDi
                            Celeron 1.2ghz
                            256mb DDR-2 533
                            80gig 3.5" SATA HDD
                            M2-ATX
                            8" Lilliput TS LCD
                              veetid... i downloaded your update and it wont even run the installer... it gives me an error window... any ideas? next time i get a chance ill take a snapshot of the error msg.... thanks
                              '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
