Anyone Destinator working in Centrafuse ?
  • Anyone Destinator working in Centrafuse ?
    Hi,
    i am really confused reading so many articles of people having d3 working embedded in centrafuse.
    My problem (and i have it since my first attempt to get this working) is that the embedded destinator windows freezes.
    Embedding, toggling between embedded and full screen mode are working very fine, but the map window wonīt move.
    The gps cursor stays and the is no action or movement in the embedded window. When i toggle between window and fullscreen mode, the gps cursor is updated to the correct position, but then freezes again.
    I am sure that d3 is still running, because when following a route, i get the audio advices (turn left) and they are right.
    Anyone who has this working ? How ? Installed special software ?
    - superbowl
    PS:
    yes, i know that this issue is mentioned in serveral other threads, but i think it is time to bundle these into one.
    i never drink water cos fish ***** in it. (w.c. fields)
    see other posts...
    if you have the latest version of NM:
    GPS path: c:\...\destinator3.exe
    GPS window name:
    Destinator 3 - [Dest3.1]
      Hi,
      i think you got me wrong, D3 embedds perfectly. But once embedded, the map window will always show the same content, there is no change while driving.
      - superbowl
        did you COMPLETELY turn of your firewall? it worked for me!
          I got it working.. I see destinator embedded, but it doesn't work well.
          The embedded screen is far to small..
            @ TheKingPlaza you can click the title screen of CF and it moves into fullscreen. Works fine for me.
            @ superbowl do you have the lastest destintator beta hotfix 3 plus CF 1.1 becuase it works fine for me with map movement etc.
              I got the same problem mate and i am using CF 1.11 and NM D3 1.1.3.
              Can one of you go through your settings and list them all . i.e D3 screen size and so on
              and just wondered if it's an overlay problem that were having with specific graphics or drivers.
              "Dont really no what i am saying so if i am way out here just tell me to shut the f*** up"
              my one is a GeForce fx5200
              Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
              The car
                Hi,
                postings of the settings of a running system might be really helpfull. I have an epia M 10000 and i use the on-board vga with the latest drivers.
                - superbowl
                  I cannot get it embedded at all. And yes, I have correct window name in CF setup.
                    Hi,
                    what did you enter as directory-path ?
                    - Stefan
                      You mean "GPS Path" in CF setup?
                      C:\DestinatorApps\Frontend_BETA3\Destinator3.exe
                      GPS window name:
                        Hi,
                        tested nearly every combination and get a little more confused.
                        I tried my system running in 800x600, 800x480, 32 bit color, 16 bit color, and all possible combinations, but still the embedded map wonīt move.
                        To confuse myself even more, the name of street where i am driving - displayed in the info-bar in the top of the destinator window - is updated very fine, itīs only the map ! so.. the windows does not completely freeze, it is the map.
                        I guess iīll send ninja a pm... maybe the fault is on d3īs end ?
                        - stefan
                          GPS window name:
                          Somebody please tell me what am I doing wrong.
                            I donīt now what you are doing wrong, the settings seems to be right, does destinator start at all?
                              my destinator starts and run purfect on its own and it embed's fine but as you say the map just doesnt move when you drive or move it with mouse. the map will only update if i touch the zoom slider but that's just one frame
                              I think these two peaces of software are the best out there and i must have
                              please help us Ninja and Veetid
                              The car
