NEW CENTRAFUSE Update 1.12
  • NEW CENTRAFUSE Update 1.12
    Another binary update. Just overwrite your current centrafuse.exe with the one in the following zip file.
    http://www.fluxmedia.net/downloads/cf-update1.12.zip
    Or visit http://www.fluxmedia.net and download the full install in the centrafuse downloads section.
    Made a few more optimizations. Should run really fast now. I fixed the display problem with the bottom nav, when switching between music and radio modes. I also think I might have fixed the video player problems. It was also jerky on my machine and the changes I made cleared it up. Hopefully it was the same problem.
    Note: Still working on the redraw of the buttons in the video/dvd modes...
    david
    just tryed it and fast is no the word
    great work david
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
      Same weird alt-tab problem Changing skins causes weird drawing errors
      Otherwise it works great
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        0l33l: I just updated the link... I fixed the skin changing problem... What speed machine is giving you that alt-tab redraw?
        note: you can remove the text on the left buttons on that skin so that it just shows the icons. Look in the skin.xml file and under global nav set enabletext = false for all those buttons...
        david
          0l33l - Any way I could get a copy of your brushed metal skin?
          VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
            Hi veetid, do you plan .NET free version? Have you also already included. button tabbed-browsing support in your time plans?
              How do I add more commands to the voice control, it works really well with my new noise cancelling mic...
              I know the commands are in ..\system\grammar.xml but I'm not sure how to actually add new commands, such as Settings, Hibernate, or Music Manager, voice scroll up/down lists... Or even better, a page in settings where voice commands can be listed and allocated easily by anybody. I think it would also be handy to include a command that would list all the available voice commands in clear text in an embedded browser window for people like me with bad memories.
              Also now that Ninja Monkey has made the D3 front end SDK D3TALK available, couldn't CF be made with D3 built in and also able to be controlled by voice.
              Another request would be links to the PSD files for your skins (Blue/Red & Black/Green) so I can add my car logo to them...
              Other than that David, GREAT PROGRAM, I'm very impressed, only thing thing that appears missing for me now (unless I've missed it) is external apps support...
              John
              My Nissan 200SX @ Silverstone
              NOW SADLY WRITTEN OFF!
              My Car's spec list + pics
              Stealth CarPC fab'ing...
                Tuned Vitesse,
                What kinda mic are you using?
                Stealth OEM spyder
                1204 dot net!
                  BTW There is a strange problem on first launch. Even if I select stretched 800x600 skind during initial config dialog, CF starts in 800x480 with all the interfece segments messed up. I have to quit the interface and launch it again. This time it runs correctly. And I STILL CANNOT LAUNCH DESTINATOR3 EMBEDDED no matter hwat I do set up CF and Dest3 front end like.
                    Its a couple of posts down, HERE
                    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                    [iGmon]
                    Download MP3 MixTapes
                      Thanks, I got a copy of it too!
                      Stop Buying New Music CD's.
                      Hit The RIAA where it lives.
                      Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
                        Hi David,
                        great work !!! My videos and dvds are playing as smooth as silk right now. great. now i only need d3 embedded working ;-)
                        - Stefan
                        i never drink water cos fish ***** in it. (w.c. fields)
                          Please....Is there anyway to not have music start playing automatically on start? My playlist starts as soon as Centrafuse loads and I don't want them too.
                          Thanks,
                          Chuck
                            works fine here, which windows are you running?
                            my destinator map resource down permanently
                              is there a reason why when i replaced the centrafuse 1.11 exe with the 1.12 exe, centrafuse opens up on my taskbar and then never opens up and then freezes my carpc (which causes me to do a ctrl-alt-del and end task) ???? should i just do a complete reinstall? hmmmm any ideas veetid?
                              '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
