Problems with D3 Embedded in Version 1.12
  • Problems with D3 Embedded in Version 1.12
    I am still having problems with D3 embedded in CF 1.12, just downloaded update again today to make sure it was the later version.
    I am having Refresh problems. When I first Open CF, I then click on the GPS button. D3 now opens. The buttons all to the left of the View button are not showing, when it first opens. I then click on the Music Button, and then back on GPS. I now can see all of the buttons. I then Exit out of CF and the D3 Map is still showing on my Display. It is not refreshing this correctly, so it is closing it all the way. If I do a CTRL+ALT+DEL, D3 is still shown as running, so it doesn't seem to be closing correctly for me.
    Now when I run D3 outside of CF, it seems to work fine.
    Is anyone else having this type of Problem?
    thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Hi,
    this is a known issue and ninja is working on it.
    - superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
      Just so that everyone knows, I was using the Stretched Skin 800x600, but changed to the 800x480 and the buttons showed up correctly, when D3 first opened. But it still seems that it is not refreshing correctly when you go to Full screen, by clicking on the Top of CF, then click it again, I again lose my buttons to the left of the House button this time.
      It seems to be better under the 800x480 resolution than it is under the 800x600. Also I tried the other buttons and they all seem to allow it to refresh correctly. It only seems to be when you click on the Title bar to make D3 go full screen, and then when you click this again to bring CF's buttons back up, under the 800x480 mode. The problems still all exist as described above in the post under the 800x600 mode.
      Just thought this might help find the issues.
      Thanks,
      Bryan
      2000 Yukon Denali
      Shuttle SN65G2
      1GB PC800 Mem
      Radeon9200 PRO
      Seagate 120GB
      ATI Remote
      USB 2.0 Hub
      Rikaline GPS-6010
      XP Pro
      750W Inverter
        Sorry for all the posts in the same thread, but I just noticed another glitch. In 800x480 the weather doesn't work correctly. It shows the Current Conditions correctly, but then the 4 Day forcast is not showing as normal. It shows Friday: then the 2 temps, and that is it. This also happens under the 800x600 as shown below in the image.
        2000 Yukon Denali
        Shuttle SN65G2
        1GB PC800 Mem
        Radeon9200 PRO
        Seagate 120GB
        ATI Remote
        USB 2.0 Hub
        Rikaline GPS-6010
        XP Pro
        750W Inverter
          bry21317: Give me the postal code you are using for weather because I can't reproduce this problem. Might be related to the data from your region.
          david
            It is 27616, it is working fine today. Must have just been a glitch the day that I was testing it.
            Thanks for the response. Sorry for the delay.
            Bryan
            2000 Yukon Denali
            Shuttle SN65G2
            1GB PC800 Mem
            Radeon9200 PRO
            Seagate 120GB
            ATI Remote
            USB 2.0 Hub
            Rikaline GPS-6010
            XP Pro
            750W Inverter
