Routis won't embed
  • Routis won't embed
    I'm using 1.12. Any ideas what's making CF not embed Routis?
    My Car PC
    If you double click on the song name it expands. u can also drag it out using the top left corner. this is assuming u put routis for the window name. good luck
      Yes I put Routis for the window name. I can resize it, but not only the bottom part gets cut off, I have to resize it every time I start CF !
      My Car PC
        asci01: Click the title bar and toggle fullscreen. This should make it fill the screen properly. Also you can click back to music and then back into GPS, does this make it properly fill the screen? It looks embedded, but it just appears on initial load it didn't get its maximize command. I have seen this happen with my iGuidance. Let me know if this is the case?
        david
          david
          Yes that does the trick !. But I have to do that every time I start CF. Any way to fix it so we don't have to do that every time?
          P.S. Great job. CF rocks !
          My Car PC
            Yep.. It happens sometimes to me using iGuidance... It will be fixed in the next release...
            david
              david
              Thanks. You the man.
              P.S. when playing a movie in fullscreen you have to double click for the movie controls to show up at the bottom. Could you change that to be a single click? Thanks again.
              My Car PC
