radiator problem
  • radiator problem
    is anyone else having the problem of CF not knowing the stored stations of radiator. i can tune and and it does all work but the presets in CF dont control radiator
    help
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    once you tune a freq you can press and hold pressed a button preset in the bottom bar for some seconds, Doing this you memorize the freq in a preset and centrafuse will remember them
    by the way, each time I woke up from hibernation in radio mode cf won't get the station and plays noise until I press a preset button
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
      Frankino: what happens if you just start up radiator by itself, tune to a station, and hibernate? does it properly restore from hibernation? Either way I think I can come up with a fix for this...
      david
        gimme 10 minutes
        EDIT
        ok ok less than 10 minutes
        it's a radiator issue, it does not tune properly when I resume from hibernation
        can you fix this using radiator ?
        Peugeot 206 1.4 HDi
        Celeron 1.2ghz
        256mb DDR-2 533
        80gig 3.5" SATA HDD
        M2-ATX
        8" Lilliput TS LCD
