mouse cursor appears during video playback
  • mouse cursor appears during video playback
    i have seclected in centrafuse to hide mouse pointer, but it wont hide. i then told windows to hide it aswell, and that worked, nut when i play video's it coms back?
    im running a 1ghz epia m1000 board with 512mb ram
    thanks
    is this a known issue?
      Same for me here, but.. i donīt care about it ;-)
      - superbowl
      i never drink water cos fish ***** in it. (w.c. fields)
        same to me here too! i saw that happening when i switch to GPS (iGuidance2.0) and then back to music... not a biggie though
        -VIA EPIA M10000/512MB/40GB HD
        -DWW motorized 7'
        -BU 303 GPS w/iGuidance/ CF
        -Opus90w
        -Belkin Bluetooth
        -Pioneer HU
        [||||||||||] 95% done
          when you tell it to hide the mouse cursor does it hide it at all? Does it only re-show the mouse when you go back to an embedded app?
          david
            yes i go to settings and disable and then enable the mouse to be hidden, return back and its fine for a while and sometimes (most of the times actually) when i come back from i guidance to music i see the mouse...
            not sure if i am supposed to get the mouse pointer on iguidance either since its running embedded anyway
            -DWW motorized 7'
            -Opus90w
            -Belkin Bluetooth
            -Pioneer HU
              I think the embedded apps are re-showing my cursor... I think I got an idea on how to fix this one...
              david
                with me, everytime i re-open cf, the mouse is back, but the setting is still set to hide, i have to unhide and rehide, and it hides again until the next time i open cf
                  For those with the Liliput TS, the driver comes with a mouse pointer profile called TouchKit Hide Cursor (or something like that) which should disable the mouse cursors for ALL apps and all Windoze usage. Not sure if that's what you're trying to accomplish, but it's an easy way to make sure the cursor never appears.
                  89 Supra Turbo
                    phatboy: Probably just a bug where I forgot to reset mouse hide on startup... I will look into it..
                    david
                      drait: I am using that function of the liliput software, but the cursor still shows in cf!!
                      thanks david, ill report back if the problem goes in the next release!
                        yup i got the same problem as phatboy
                        CarPC status: iPod, 3,456,217 songs so **** you
                          Same here.
                            I am using girder for automation and zoomplayer. Sometimes the cursor happen to pop up for no reason, but I but it in the lower-right corner (cannot see it) with girder when I am playing videos.
                            the trick is to put it where it doesn't bug you.
                            -Mars
                              Hmm, well, there went my .02 I'm guessing that it's not relying on the system cursors (or the ones defined in the selected mouse profile) if it's still displaying.
                              89 Supra Turbo
