Touchkit setting vs volume +/- !
  • Touchkit setting vs volume +/- !
    If your +/- volume buttons do not work with on centrafuse with a touchscreen then you chould set on your touchkit configure utility (in settings tab) the 'Mouse mode' to 'Normal mode' (it is default), 'click on touch' does not work on these +/- buttons!
    In 'click on touch' mode all centrafuse buttons work except these 2 volume buttons
    This took me a while to find out what this problem was...
    EPIA M10K, 512MB RAM, 60GB
    [##########] 100% (since 1 March 2005)
    snowboarding.be - bokky.com
    Its a common problem. The vol thread doesn't get terminated properly.
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Is this "click on touch" option the solution to all the volume problems? I will turn it on tonight and try to reproduce.... I hope this is what it is... I was lost on that one, never could reproduce the problem...
      david
