Found a cool feature of CFuse
  • Found a cool feature of CFuse
    Found a cool feature of CFuse ....
    while in the GPS window (NM/Dest/MapMonkey) within CFuse the small window embeds in the center of the screen. If you click on the top bar ( left of cell signal meter ) the GPS goes to FULL SCREEN, click it again and it returns.
    It also does this for Traffic window as well, and maybe WEB window (not sure )
    Not sure if this is a known feature
    The only problem is the music buttons don't work when in full screen.
    yup, its pretty coool. I think its in the documentation though
    Stealth OEM spyder
    1204 dot net!
      Yeah it is. This also works the same when you're connected to the web for web, traffic, weather, etc.
        somewhere there was a post that showed how to adjust the music or full screen window so that the bottom buttons still show.
        Randell Kelly
          If you open the skin.xml file for your current skin and search for the EXTERNALAPPS section, you will see a FULLWIDTH and FULLHEIGHT tag. This is the definition for the fullscreen size. You can just lower the FULLHEIGHT until the bottom buttons show back up...
          david
            david
            Cool, that will workout great.
              Heres my post with a screenshot on this - HERE
              [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
              [iGmon]
              Download MP3 MixTapes
