replacing RADIO button with another Application ??
  • replacing RADIO button with another Application ??
    I don't have a radio card or XM radio on a system and would like to have a button on CFuse open/embed an application called TopoUS ( topographical GPS )
    I know that I can run it along with Destinator / MapMonkey as I have a port splitter for the GPS antenna.
    I looked through all ini/xml files and could not find where to do it..
    If it was staring right at me, I am sorry for being an idiot
    Thanks in advance for any help
    Don
    in the CF configuration wizard you can specify an external radio tool and a window name, that's all you need for embed any program, the last step is to modify the skin xml file, remove "RADIO" label and put whatever you like
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
      actually modify the language file to just change the text from Radio to something else..
      david
        david
        that's what I ment
        Peugeot 206 1.4 HDi
        Celeron 1.2ghz
        256mb DDR-2 533
        80gig 3.5" SATA HDD
        M2-ATX
        8" Lilliput TS LCD
          Worked great !!!
          The only issue is when I have the 3D map AND the 2D map displayed ( Topo USA ) side by side, the 3D screen flickers when embedded in CFuse and doesn't do it while it's a standalone.
          Dest3.1 & TopoUSA work at the same time due to com port splitter and having TopoUSA in place of "Radio" button is great since I am using my HU for radio
          Thanks again guys, yet another successfull tweak, now I just gotta get the weather screen to use Port:8080 ( BT cell T-mobile proxy )
            Here are some screen shots of what it looks like
            sorry for multiple posts as only one will show up
            First what it looks like as a standalone w/ 3D view enabled
              now some other shots
              with buttons and Topo info bar
                with buttons and no Topo info bar
                  without buttons and Topo info bar
                    without buttons and fullscreen
                      seems to me a great software, the first image on the left with in 3d is great
                      Peugeot 206 1.4 HDi
                      Celeron 1.2ghz
                      256mb DDR-2 533
                      80gig 3.5" SATA HDD
                      M2-ATX
                      8" Lilliput TS LCD
                        Just installed Topo USA version 5 ..
                        looks a little better than version 4 and has " car / nightime " colors and some other functions added, like the ability to print.
                        unfortunately the 3D screen still flickers when embedded....
                        maybe I'll just embed Ver 4.0 and keep in 2D mode, and run Ver 5.0 as a standalone with 3D and switch between ala alt-Tab ????
                        The 3D is too cool !!!!
