Why is CF invisible in PCanywhere?
  • Why is CF invisible in PCanywhere?
    I'm trying to work on my carPC system and I'm doing it from my office PC because of the bigger screen and a real keyboard. I use PCanywhere to the carPC and it works fine EXCEPT that CF does not appear on my office monitor!!! Why is it not shown across PCanywhere connection when none of the other apps I run are? I"ve set colors at 256 or 16k with same results.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    weird... It shows up fine with Remote Desktop and Remote Admin, two other programs that perform similiar functionality...
    david
      Try realvnc.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        I got the same "problem" with TightVNC. I'm sure realVNC wont work either...
        Current Setup
        Nexus 7 Tablet
        Built in head unit
        Brutus 1500Watt Amp
        Two Boston 12" subs
        2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
          may try tweaking the display resolution on vnc session.
          Randell Kelly
            Operating Centrafuse via Vnc .... Video Overlay?
            Im sorry to tell that since Veetid changed the screen update from version 1.1 and above. And after that vnc (or other related product stopped working). I uses a PDA with VGA resolution as remote control but Im forced to stay with 1.1
            I believe tha Veetid chanced to use video overlay instead of traditionel screen update and thereby stopped the support for vnc programs.
            Veetid, Im hoping that this could be a feature you could enable or disable in the future version so us using vnc still can use your perfect software.
            /ProCos
              i use realvnc and it works great
                After 1.1 I did start using layered windows but your VNC client should support it... I have personally used realvnc, remote desktop, and remote admin... All work fine... Maybe switch your remote program to one that supports layered windows.
                david
                  I just installed UltraVNC and it still doesn't show CF on the remote PC. How do you guys that are using it successfully have your config set?
                    Any solutions to this ? I still can't get it to work
                    Current Setup
                    Nexus 7 Tablet
                    Built in head unit
                    Brutus 1500Watt Amp
                    Two Boston 12" subs
                      I use RealVNC with the default settings and it works fine with CF.
                        ultravnc for me, it does not show cf window, not a big problem but very strange
                        Peugeot 206 1.4 HDi
                        Intel Mini-ITX Mainboard
                        Celeron 1.2ghz
                        256mb DDR-2 533
                        80gig 3.5" SATA HDD
                        Sb Live 5.1 w/ KXProject Drivers
                        M2-ATX
                        8" Lilliput TS LCD
                        100% installed and working :D
                          It most likely is my use of layered windows... My upcoming version doesn't use them, should work fine....
                          david
                            Well I downloaded the latest version of RealVNC and it works fine
                            Current Setup
                            Nexus 7 Tablet
                            Built in head unit
                            Brutus 1500Watt Amp
                            Two Boston 12" subs
                              I have used the Remote Desktop built into XP pro and it works fine, connecting to the CarPC and seeing CF.
                              2000 Yukon Denali
                              Shuttle SN65G2
                              Cel-D 2.4 GHZ 533mhz FSB
                              1GB PC800 Mem
                              Radeon9200 PRO
                              Seagate 120GB
                              ATI Remote
                              RF Mini Kb w/Trk Ball
                              7" Lilliput Touch Screen Monitor
                              USB 2.0 Hub
                              Rikaline GPS-6010
                              PN11 802.11b Wireless
                              XP Pro
                              750W Inverter
