Generating MP3 index not with CF
  • Generating MP3 index not with CF
    Little but important question...
    My MP3 archive is about 30GB I sync the archive between CarPC and my local server. Now as you probably know generating the MP3 index takes a long time.
    Now my idea is to generate the MP3 list on my server and sync it to my carpc.
    I found that the current.mpl file contains the current playlist mp3 files (plain text) but I can not find the full mp3 index file! Did you put it into a sort of Database file (binary, genrelist.day maybe)?
    Could you share us your way of doing it David? It would save a lot of time if I can generate the MP3 index every night on my server instead of on my CarPC.
    Thanks...
    EPIA M10K, 512MB RAM, 60GB
    [##########] 100% (since 1 March 2005)
    snowboarding.be - bokky.com
    main.dat is where the full mp3 index is kept... This is also the location of the local freedb storage... It is a MS Access file...
    david
      Pfff... MSaccess... This will give me a biiiig challenge to get that to work on Linux...
        linux is for sissy's :P:P
        my destinator map resource down permanently
          indeed because Windows is too hard to find out what is wrong with it... even the creators can not do it
            You could make a csv on the server and then have a little program on the carpc convert / import that into the access-db... should be quick as there's nearly no io involved, and that's what takes so much time.
            Just an idea ;-)
            List of front-ends/usefull apps
            XTroniC | XTroniC Direct
              I know... found the software, now the time... but first some sleep...
                If the directory structure was identical on the CarPC and Home PC would it be possible to create some sort of playlist in Winamp or other app and transfer the playlist to CF in the car ???
                Just like many here and the original poster, I have many many MP3s and I am dredding making playlists within CF ...
                Not any negative on the application, but TS friendly app is harder to do these things than within something else..
                CFuse
                  Don 944 LA: Just create a playlist in CENTRAFUSE and then open it with a text editor... I store them in the playlists sub folder... It is a very easy structure to follow, you could easily make them on your PC and then just copy them into your CENTRAFUSE playlists folder...
                  david
                    veetid i'm off to bed now i do wan't to see 1.2 in the morning!!! :P:P haha kidding take you're time nite all!
