Running Centrafuse as shell
  • Running Centrafuse as shell
    I get a "common language error" when I try to run centrafuse as shell. However, when I boot into explorer and run centrafuse, everything is fine and dandy.
    I installed all 3 files on the veetid's page if that helps.
    Anyone got a clue as to what is going on or if I need to specifically run certain files/services in conjuction with CF?
    I would like to know if there is a way to do this as well. I have tried this and had problems as well.
    Randell Kelly
      Not sure if that's possible.. (yet?)..
      Dr. Ron Paul for President 2008
      Hope for America - http://www.ronpaul2008.com
      Who is Ron Paul? - Why do we need Ron Paul?
      CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
        I have run a .NET app as a shell before, so it's not the .NET framework that's a problem.
        Maybe there are dependancies on explorer? Or perhaps on the something else that explorer would load.
          Sorry for digging up old posts but is there any progress on this?
            It's on my list of things to look into...
            david
              i set frodo's LMF to be the shell, and made that launch centrafuse... works great!
              btw amazing peice of software - THANKS! can't wait for the next release!
                hey, good idea! I'll try that as soon as I get time.
                Randell Kelly
                  it just saves a few precious seconds of boot time...! but i couldn't say i noticed any performance increase once it's running.
                    Just an FYI, it doesnt make a lick of difference if youre doing hibernation
                    2004 G35 Coupe project
                      yeah. I figured as much after I thought about it far a second...
                        for me it does not work to set frodo's LMF as shell and start centrafuse as application. on startup the system hangs in a case, i get the same error message if i set centrafuse directly as shell (anything like language error ....). centrafuse as shell would be very nice.
                          Ionno, I simply use a bat file as my Shell which launches Centrafuse first and then the explorer shell. Works fine.
                          Code:
                          cd "\Program Files\iNav\iGuidance"
                          start iGuidance
                          sleep 30
                          explorer
                          For sleep, you will need to download the file online.
                          Mark
                          Website: http://www.greenpowerenthusiast.com/
                          Car'Puter Project
                          - Xenarc 700TSV
                          - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
                          - 1x 256MB Corsair XMMS DDR400
                          - M2-ATX
                          - Belkin 802.11G W-Nic
                          - Garmin 15H GPS
                          - WinXP SP2 (NLited)
