GPS Window revisited
  • GPS Window revisited
    This is the string I entered in the GPS window of Centrafuse fot SA 2005, but it dosen't work:
    Street Atlas 2005 / DeLorme Street Atlas USA%trade 2005 - Map File 1
    Is there anything else I need to do to get the program to properly dislplay in the Centrafuse window instead of coming up full screen?
    Have you tried just "Street Atlas" ?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
      make sure you are in map file 1 and not one you named.
      1990 Jeep Cherokee
      2000 VW Golf TDI 4dr
      2005 VW GTI MKIV - SOLD
        I am now having the same issue with the new version of centrafuse just loaded. Mine worked fine before. I am on Map File 1. and I even retyped it.
        Randell Kelly
          well, I just uninstalled and rolled back to beta 1.0.0 and Street Atlas embeds ok again.
          by the way Mr. Blue, you are right the window name is...
          "DeLorme Street Atlas USA%trade 2005 - Map File 1" with out the quotes of course..
          I don't know whats up, must be somehting to do with the new windowing stuff.
          Randell Kelly
            I will take a look at it... I did change some things between those versions relating to the embedding...
            david
              Any luck in finding out what's wrong with the new version?
