Music problem.
  • Music problem.
    can't seem to find anything to help with this.
    CF b1.20
    EPIA M10000
    256Mb DDR2100
    1x 80Gb HDD for OS and apps
    1x 40Gb HDD for Music
    Onboard audio latest and Direct X version
    Currently plugged in to a normal PSU beside me.
    Music just wont work right I get crazy interference it sounds like drum beats and sometimes like a dial toneish sound.
    No idea what to do :/
    Current Honda Accord Aero Deck install
    http://mp3car.com/vbulletin/showthread.php?t=78717
    96' Laguna install
    http://www.mp3car.com/vbulletin/showthread.php?t=45365
    Are you currently testing it inside car or outside car audio system? How is your audio out connected to your input device? Through HU or directly to your amp? Through analog or SPDIF?
    You will have to let us know more details man...
      I have just realized what forum you posted in. Does it mean you are only having issues under this specific frontend? Did you actually tried playing files that you are having problems with directly from Windows using lets say Media player?
        the pc is currently beside me set up as a home pc of sorts normal PSU, CRT monitor and 2.1 speaker set up (did the same when I had it plugged in my TV)
        It only happens with Centrafuse. WMP and MediaEngine work fine.
        I have the managed dx thing as well so I have no idea, the only thing I can think is I have heard PCI wifi cards cause problems but I need to use this I dunno if I get a USB soundcard if it might help.
        96' Laguna install
          I dont think there is anything wrong with onboard audio. I have been testing CF while ago and I have had no problems with audio quality at all (XP SP2). What OS are you running?
            Xp Sp1
            I just pulled the wifi card out, same problem.
            Look like the best bet is to get a USB soundcard when I get paiud and see if it helps.
            96' Laguna install
              It seems something might be wrong with your windows install... Try an old restore point, uninstalling directx and managed directx and re-installing, or maybe re-installing windows itself... You shouldn't have to get an external sound card...
              david
                david
                Ok then, going to pick up a new 120Gb HDD next weekend when I get paid and order everything else, hopefully that wil lclear it up then.
                Cheers.
                96' Laguna install
                  I read somewhere about codec packs messing with mp3 playback, try to remove such stuff if you installed it
                  Peugeot 206 1.4 HDi
                  Intel Mini-ITX Mainboard
                  Celeron 1.2ghz
                  256mb DDR-2 533
                  80gig 3.5" SATA HDD
                  Sb Live 5.1 w/ KXProject Drivers
                  M2-ATX
                  8" Lilliput TS LCD
                  100% installed and working :D
                    odd thing is when i'm playing music on my home pc and my wireless lan card is accesing the hub with something large it sounds distorted have no ide why though
                    God, All this <Matt's System > in an '05 760Li Would kick ***
                      Frankino, thank you very, very much you were spot on
                      Still going to get a 160Gb HDD as an excuse to replace the two old ones
                      96' Laguna install
