Plugin Development
  • Plugin Development
    Hi at all!
    Is it possible to write your own plugins? I have a nokia 6230 telephone, but phonecontrol don´t support it correctly because i use a datacable. I use the nokia sdk to communicate with my telephone.
    An now my question. Is it possible to write a plugin for centrafuse?
    Sincerely BonkersDeluxe
    Get a firmware upgrade to 5.2 for your phone and it will support it correctly.
    Skinning to go... VisualDesigner2!
      Hi zorro
      My firmware is 5.24. Is this OK? Do you have an idea to fix the connection problem? I don´t have bluetooth or irda only datacable. I hope you can help me, because i have bought phoncontrol before i get my telephone.
      Thanks!
        Should be ok. What is the problem with the cable connection?
          Thats my configuration.
          <Communication id="Nokia">
          <Port>6</Port>
          <Setting>38400,N,8,1</Setting>
          <Vendor>Nokia</Vendor>
          <PhoneBookLocation id="1" timeout="60">ME</PhoneBookLocation>
          <UseCharset>8859-1</UseCharset>
          <UseClip mode="1">True</UseClip>
          <UseCPAS>False</UseCPAS>
          <UseCLCC>False</UseCLCC>
          <UseCNMI mode="2,1">True</UseCNMI>
          <UseCRC mode="1">True</UseCRC>
          <Keypad quote="False" terminate="False">+VTS</Keypad>
          <UseReset>False</UseReset>
          <IgnoreMS>True</IgnoreMS>
          <SMSStore>SM</SMSStore>
          </Communication>
          The com port ist the port from the nokia 6230 Modem is this OK?
          I get this error : "Öffnen des Kommunikationsanschlußes ist fehlgeschlagen!
          Bitte sicherstellen, dass der richte Anschluß verwendet wird."
          But "Manuelle Wahl" is possible. Disconnect don´t work
          In Phone Test i get the error " {-ResString not found -} "
          Thanks!
            I think, you're mixing things up.
            It's not possible that you dial out if the port is not open. Beside, after this message PhoCo will shut down.
            If the port is correct or not, PhoneTest will tell you that. You must not have any other PC-Suite / Connection manager running while PhoCo tries to connect.
              I have close all nokia programs.
              Why?
                Old version
                But basically this means "No response". Did you try HyperTerminal?
                  What is HyperTerminal? How can i use it?
                    PhoCo Manual, Chapter 10ff
                    (Note to myself: Don't ever provide a manual again ... it's a complete waste of time)
                      Ok this works!
                      It shows the name of my telephone.
                      What iám doing wrong. Hmm
                      Is my configuration correct?
                        Two things you may try: Add "Handshake" to your "Communication" section and set it to "Hardware" and set UseCD to True.
                        If you don't have "Handshake", download the latest version here: http://phoco.net/tmp/PhoneCtl.NET.zip
                        If this doesn't help either, I have to check it myself with a 6230. I have a 3100 with a cable connection but it seems not to be the same...
                          Ok I have tried it out. but no change.
                          When you have another idea let it me know.
                          Thank you for your support!!
