MP3 Problem in Centrafuse
  • MP3 Problem in Centrafuse
    HI first of all. Total newbie using centrafuse.
    To the problem, when i play a mp3 with centrafuse it makes a really odd popping noise, i played the same file with mediaplayer and it worked perfectly. When playing a movie or a dvd it is fine, it is even ok with a cd. I even went to the extreme of purchasing a 5.1 external sound card but this still has not cleared the problem. SO in a nutshell this only happens with mp3
    Please help if you can, thanks in advance
    Mark
    After listening a bit harder it sounds like it has an echo if that helps, but still only does it with mp3
      maybe a codec issue, did you install something like nimo codec pack or similar? if so, uninstall and retry
      Peugeot 206 1.4 HDi
      Intel Mini-ITX Mainboard
      Celeron 1.2ghz
      256mb DDR-2 533
      80gig 3.5" SATA HDD
      Sb Live 5.1 w/ KXProject Drivers
      M2-ATX
      8" Lilliput TS LCD
      100% installed and working :D
        Yes i did install nimo codec pack to get the video to play as it requires the codecs. If this is the problem, which codecs are you using for your system ?
        Thankyou for the help
          single codecs, ffdshow for mpeg4 decoding, windvd filters for mpeg2 decoding
          nothing else for me, if you need other codecs install them one at the time, do not use integrtors like nimo, or at least deselect mp3 codec during installation, maybe it prevent the decoding problem
          Peugeot 206 1.4 HDi
          Celeron 1.2ghz
          256mb DDR-2 533
          80gig 3.5" SATA HDD
          M2-ATX
          8" Lilliput TS LCD
            Thanks for all the help. It was the codecs so i removed them and downloaded just the divx codecs from DIVX.COM.
            Everything is working great now
              why not ffdshow? it gives full mpeg4 decoding, so divx, xvid and others mpg4 baset are decoded with no problems. it also includes very powerful post processing filters
              take a look
              Peugeot 206 1.4 HDi
              Celeron 1.2ghz
              256mb DDR-2 533
              80gig 3.5" SATA HDD
              M2-ATX
              8" Lilliput TS LCD
                I'm having the same exact issues. Had issues with codecs before, hopefully your solution will work for me.
                -HD
