Video aspect ratio workaround
  • Video aspect ratio workaround
    I found out this trick to get correct aspect ratio in video modes, until david fixes it (maybe it could be avoided now)
    using ffdshow to decode the video (for mpeg1-2-4 and tons of other codecs) under "Resize & aspect" on the bottom of the page, simply select "keep original aspect ratio" , and enable the resize tab in the left colum. it works perfectly
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    This is good news... I was having some difficulty getting the proper aspect ratio without modifying the codec like you did... I am still working on it though, but this is an great work around... If you are using other codecs like Nvidia or PowerDVD they have similiar options as well...
    david
      I'm trying to force ffdshow to decode mpeg2 streams too, I know it can be done, if anyone could help..
      EDIT
      found. simply select the libavcodec for all the codecs in ffdshow options, it processes the video (and fixes the ratio) and then passes the stream to the decoder
      Peugeot 206 1.4 HDi
      Celeron 1.2ghz
      256mb DDR-2 533
      80gig 3.5" SATA HDD
      M2-ATX
      8" Lilliput TS LCD
        david
        sorry to revive an old thread, but will 1.3 include an option for video/dvd aspect ratio correction internally?
        Dr. Ron Paul for President 2008
        Hope for America - http://www.ronpaul2008.com
        Who is Ron Paul? - Why do we need Ron Paul?
        CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
          I think ffdshow method works well with 4/3 screens, for 16/9 some testing is needed
          Peugeot 206 1.4 HDi
          Celeron 1.2ghz
          256mb DDR-2 533
          80gig 3.5" SATA HDD
          M2-ATX
          8" Lilliput TS LCD
