Tip! Get speed cameras into Centrafuse/D3
  • Tip! Get speed cameras into Centrafuse/D3
    I guess some of you already know about this. There is a way to get speed cameras onto the map in Centrafuse Destinator.
    It will not warn you for the cameras, but they will show on the map.
    Make sure you have the latest version of Map Monkey:
    Latest hotfix: http://www.mp3car.com/vbulletin/showthread.php?t=44805
    Latest speed camera dB: http://www.mapmonkey.net/
    Go to MM configuration -> Adv. GPS.
    Select Tools -> Import new cameras, and select the correct CSV file.
    Then Tools -> Copy to favourites (This might take a couple of minutes)
    Next time you use Centrafuse, make sure the imported speed cameras option is tick (under favourites)
    Now the speed cameras will be visible on the map.
    / Micke
    Excellent stuff mate. I wonder if anyone knows how to get the warnings working in centrafuse??
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
      but then your not using the integrated destinator............
        Hi OriginalNick2,
        I think I am? Im not lanching MM. Just using its config to import the cameras into favourites.
        / Micke
          Micke, you are using the integrated destinator. Configuring MapMonkey differently somehow seems to alter the setup of the integrated destinator support in centrafuse.
          FociMan
          8" touchscreen
          D-Link USB Radio
          USB GPS Mouse
            That's because they both use the same files.Or should I say the Destinator files are installed in the default location by both programs.
            Laidback
            The ultimate CarPC - Wow!
              cool - didnt know that
                The warnings side will have to be coded in Centrafuse to work, this is custom, not a standard part of the Destinator frontend sdk.
                  ok thanks for that UKMP3Car. I wonder if this is planned for Centrafuse 1.3? One for David to answer I think...
                  FociMan
                  8" touchscreen
                  D-Link USB Radio
                  USB GPS Mouse
                    you can actually get a audio alert, simply do the following
                    goto C:\DestinatorApps\Destinator\Common\Favorites
                    delete Auto Alert 1.dat file, rename the speedcam.dat (might be FEspeedcam, unsure which one MM creates) file created by MM to Auto Alert 1.dat, then in Fav's on cent, tick the alert1 box, if you like you can also change the alert1 icon in the same folder as above to the speedcam one.
                    cdr
                    Follow me on Twitter
                    http://www.FreeICE.co.uk
                      Excellent stuff. Now we're making progress... All we needed was the right person to stumble on our little thread!!
                      FociMan
                      8" touchscreen
                      D-Link USB Radio
                      USB GPS Mouse
                        cdr
                        And, if I remember correctly, you can change what it says as the alert as well.
                        Or, all you needed was to ask the right people!
                        Edit2:
                        Code:
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,141;1,"Poi Alert 1"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_1000,0,0,141;2,"Poi Alert 2"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_800,0,0,141;2,"Poi Alert 2"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_600,0,0,141;2,"Poi Alert 2"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_400,0,0,141;2,"Poi Alert 2"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_100,0,0,141;2,"Poi Alert 2"
                        ::MW,POI_ALERT_2*DISTANCE_TYPE_50,0,0,141;2,"Poi Alert 2"
                        141 is the name of the wav file - '141.wav' and it says 'favourites alert'. So either edit the above lines in 'DestinatorVoiceManeuvers.inf' to point to another wav file or re-record '141.wav'.
                        Laidback
                          perhaps when someone gets this working they could post the edited files ???????????
                            Any update on this one guys - read with interest!
                            Ice: Nakamichi MB100, Dynaudio 340, Genesis Dual Mono, JL 12w2, Epic 160
                            Current Project: Fitting a Cologne V6 to an Eagle SS
                              Is this posible to have the speed camera file uploaded into Delorme street atlas and Co pilot as well?
                              Opus case. MB 899 core duo 2.0ghz
                              Dual vga out, 400 gb hard drive, Centrefuse front end
                              zapco 1000.4 for zapco 6.5 componets
                              zapco 1100.1 for 2 13" W6.
