CF1.4 List of Apps to embed.
  • CF1.4 List of Apps to embed.
    Want a list of programs i could embed as im running out of ideas....
    what have you lot got?
    GPS,
    Internet Explorer / MobileWeb / Firefox,
      e-mail client? wifi locator?
      Stealth OEM spyder
      1204 dot net!
        What is the window name for Internet explorer?
          why using IE??
            any decent wifi location software?? I would LOVE to see some sort of tie in between the GPS mapping and the netstumbler-like software.. even if it would just allow for some "bookmarks" or similar demarkation on the maps... the netstumbler / stumbverter setup is just too many steps for just trying to locate a local hotspot...
            EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
              Originally posted by OriginalNick2
              why using IE??
              Why not to use IE. It's likely to be already on the system.
              It starts faster then for example FireFox.
              The bullxxx about bugs goes up for every client.
              And something thats most imported for other apps, its supported by almost every site on the internet. Something you can't say about the other clients that don't use parts of the IE modules
                If 90% percent of the planet had cancer, would you then also think that cancer is the default way to die for humans or would you rather live longer and die of old age!
                But this is getting to be off-topic...
                EPIA M10K, 512MB RAM, 60GB
                [##########] 100% (since 1 March 2005)
                snowboarding.be - bokky.com
                  I love that analogy of IE.
                  We are, will have and forever will be...
                  But not tommorrow!
                    My main apps are iGuidance (GPS) and TMO (OBD DataLogging).
                    All others are for configuration: explorer.exe (which now starts on the desktop folder thanks to the new <parameters>), Girder, and Delorme Serial Emulator (but that's just to start it since I can't figure out how to use AutoIt to right-click its tray icon and then click "monitor..." [especially since there is no "tray" as CF is the shell]).
                    PS: I have tried to convert myself to FireFox multiple times. Although it has a lot of things I love, it is missing things IE has that I can't live without (no, I'm not going to list them... at least not in this thread).
                      I successfully embedded:
                      - MapMonkey (but still hibernate-GPS-reconnect problem)
                      - Firefox
                      - Windows command box
                      - Cygwin command box
                      - MBM5 (only closing does not work yet, system tray issue)
                      - notepad
                      IE side topic: read this: http://it.slashdot.org/article.pl?si...id=113&tid=218
                        ANy of you with Routis 2004 able to embed properly without the use of skinbedder? if so, any suggestions of what you did?
                        replicant
                        Audi A4 (flickr pics)
                          i got
                          MM
                          R4
                          IE
                          NOTEPAD
                          CALC
                          and net stumbler
                          Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
                          The car
                            - notepad
                            Two command-lines and no explorer? You use Cygwin but not TextPad instead of Notepad?
                            Anyway... the real reason I replied is: What's MBM5?
                              MotherBoard Monitor 5
                              Dr. Ron Paul for President 2008
                              Hope for America - http://www.ronpaul2008.com
                              Who is Ron Paul? - Why do we need Ron Paul?
                              CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
