CF Won't Start
  • CF Won't Start
    Since 1.3 came out, I installed it, and it worked, and I changed the settings, and I guess I changed something that shouldn't have been changed. So it wouldn't start, and it kept giving me this exception message listed below. I uninstalled it and reinstalled it, and it still gave me the message. Then I uninstalled it, and deleted the folder, and reinstalled 1.4, and still. Here is part of the error message:
    Code:
    Exception message:
    Process performance counter is disabled, so the requested operation cannot be performed
    Exceptiontype name:
    System.Reflection.TargetInvocationException
    Exception Assembly name:
    mscorlib, version: 1.0.5000.0, culture=neutral
    Publickey Token = b77a5c561934e089
    Anyone know what the problem is? I'd like to run this beautiful piece of software.
    windows detect some sort of problem and has disabled your performance counters, which I use in the first part of centrafuse load to determine if it is already loaded...
    I will change this to not use the performance counters anymore... For now you can reenable your counters by deleting...
    HKEY_LOCAL_MACHINE\SYSTEM\Curr*entControlSet\Servi ces\PerfProc\Performance\Disable
    if it exists...
    here is the reason it happens...
    http://msdn.microsoft.com/netframewo...aspx#Question2
    david
      I tried deleting the Performance folder, and it still performs the same error. There is no disable key anywhere in that folder, nor is there a folder called Disable. Anything else I can do?
        I will take this code out so you will not have this problem anymore after the next update...
        Try to search on how to re-enable performance counters in XP...
        david
          OK.. Do you know how much longer the next update will take? I got a pretty long road trip coming up tomorrow..
            won't have one out that quick... you need to either re-install XP or find out which service got it's performance counter disabled...
            http://www.microsoft.com/resources/d...ntry/94214.asp
            david
              Problem with CentraFuse and XP Professionnal NLITEd
              For those which have the error message :
              «Performance counter is disabled…. »
              Download PerfProc.dll from here :
              http://www.dlldump.com/download-dll-.../download.html
              Place it in :
              C:/Windows/sytem32/PerfProc.dll
              Make a .reg file with the following text : (.txt file renamed in « blabla.reg » and double-click on it)
              Windows Registry Editor Version 5.00
              [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\PerfProc]
              [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\PerfProc\Performance]
              "Close"="CloseSysProcessObject"
              "Collect"="CollectSysProcessObjectData"
              "Collect Timeout"=dword:00001f40
              "Library"="perfproc.dll"
              "Object List"="230 232 786 740 816 1408 1500 1548 1760"
              "Open"="OpenSysProcessObject"
              "Open Timeout"=dword:00002710
              "WbemAdapFileSignature"=hex:2b,c8,83,a7,35,21,fa,7 3,c0,54,99,3d,f3,7e,cf,d3
              "WbemAdapFileTime"=hex:00,e0,8c,f6,b8,2f,c1,01
              "WbemAdapFileSize"=dword:00008c00
              "WbemAdapStatus"=dword:00000000
              REBOOT system
              And after CF should work…It works for me
              Brice
              New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
              Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
              Home Made In-Dash 7" Lilliput V1
              Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
              First project in Peugeot 306
                Error Image
                I am getting the above error when starting CF.
                If this will not be an issue with the next release, then nevermind, otherwise, how do I make it work?!
                Jarrod - Holden VX S!
                  Originally posted by Jarrod
                  Error Image
                  the post right above you explains how to fix it...
                  david
                    I have a similar problem running CF on my vmwared xppro, the fix above didn't work
                    Peugeot 206 1.4 HDi
                    Intel Mini-ITX Mainboard
                    Celeron 1.2ghz
                    256mb DDR-2 533
                    80gig 3.5" SATA HDD
                    Sb Live 5.1 w/ KXProject Drivers
                    M2-ATX
                    8" Lilliput TS LCD
                    100% installed and working :D
                      Just to let you guys know,
                      I just got the error to. This is after i did a windows update 2 days ago
                        the upcoming release doesn't use performance counters...
                        david
                          Sorry, forgot to mention I tried the above fix and it didnt work.
                          When will the upcoming release be available?
