CF 1.4 and MM 1.3.xxx
  • CF 1.4 and MM 1.3.xxx
    I tried out MM for the first time last night, and guess I need to do some reading on how to use MM.
    But what skin do you guys use? Even in full screen (with the CF menu bar on top) i still can enter a new destination, because thatīs in the top of the windows where the CF bar is.
    Also my Windows processline suddenly appears when running MM in CF, my friend had this problem on CF 1.2 also.... I tried with and without OnTop enabled no luck. Anyone else with this problem?
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
    Checkout this MapMonkey skin for CF 1.4.
    You can download the skin here. It includes Paint Shop Pro 9 files if you want to finish it completely (the OSK hasn't been re-skinned yet)
    You should unzip it so that the Skin.ini (and other files) inside the Zip are in this folder: C:\DestinatorApps\Map Monkey\Skins\Centrafuse2
    And launch the Map Monkey configuration to select the new skin.
    Attached are the external.xml and buttonactions.xml in case anyone needs them for reference for launching Map Monkey.
    Found all info on this Thread
    Thank stevieg for this. Im just spreading the word.
      What about Freedrive !!!
      Come on CDR stick your 2p in
      @Tronic - Can you clip and share the sections of your XML files that make GPS a main menu option and how to make FD/MM work...
      My Nissan 200SX @ Silverstone
      NOW SADLY WRITTEN OFF!
      My Car's spec list + pics
      Stealth CarPC fab'ing...
        Very nice skinning by the way, forgot to mention that
          No one's taking me up on this one...
          Has anyone got Freedrive to embed properly in CF1.4b?
          I've got the buttons working as i want but it won't embed, even tried the bat file route???
          If so, how...?
            If so, how...?
            hmm i tried but i don';t know what the window name is...
            my destinator map resource down permanently
              BUMP!
              same here.
              Can somebody shed some light on this one...?
                I have edited my first post and added the modified XML files. Now you got everything you need.
                Note that I am running this in 800x600.
                  Can you get Freedrive embedded or only MM?
                    Tried the skin, but I still canīt see the top of the program, where the Street, City, Number part is when setting a new destination?
                    Anyone else?
                    I assume the windows processline problem is a MM problem when in full screen, because CF doesnīt control it at that point...
                    /SOS/
                      Freedrive embeds just fine after a couple of tries, the windowname i use is "FreeDrive"
                      Epia M10000 512Mb 80GB, Xenarc 7", Holux GM-210, still doing the Destinator vs. iGuidance challenge in europe.....
                      SAILCAT
                        I can't try it a couple of times though as CF needs to restart once FD is closed in order to re-open it...
                        FD will open, it just won't embed...
