centrafuse and webcams.... ?
  • centrafuse and webcams.... ?
    hi id like to add a webcam to my system but unsure if i can view it trew centrafuse? is this posable...
    i want to gut out one of my fog lights and mount it in there
    but im unsure of how i will get this displayed on centrafuse (its set on shell and i noticed nothing else loads up exept centrafuse...
    also is it posable to have 2 cams (one front and one rear?) and view them indipendantly threw centrafuse? (switch between the 2 as and when i like)
    also is it possable to record off the cams?
    with sound?
    id like to keep everything within cetrafuse so i dont have to exit it and open other programs to use the cams....
    cheers for any help
    I really want multiple cameras and recording as well, hopefully someone will be able to do it
      could you maybe embed a webcam viewing/capturing program like Gotcha! into CF and view/record them that way?
        i haven't found any touchscreen friendly webcam apps so far.
        entr0py wrote a little app that will display the image from a webcam and caputure an image, but doesn't record video. It looks promising, however, and I hope he will expand on it. http://www.mp3car.com/vbulletin/showthread.php?t=56195
        Dr. Ron Paul for President 2008
        Hope for America - http://www.ronpaul2008.com
        Who is Ron Paul? - Why do we need Ron Paul?
        CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
          thats exactly the thing im after but with a capture so i can record video from track days ect...
          thanks mate
          one thing i have NO clue at all on is how to "embed programs into CF"
            embedding applications into cf is a matter of modifying the external.xml file located in the \flux media\centrafuse\system\ directory.
              frodocam?
              List of front-ends/usefull apps
              XTroniC | XTroniC Direct
                Originally posted by JC-S60
                frodocam?
                well - touchscreen friendly yes; but captures neither image nor video, and i was unable to get it running on 3 different PCs, so I've given up on that one.
                  sorry im a noob to this... how do i go about modifying .xml files?
                  what exactly do i have to do to do it?
                  cheers for your helpmate
                    http://www.mp3car.com/vbulletin/showthread.php?t=55154
                    That should show how to imbed using the external.xhtml.
                    ~Tangeray
                      i used Frodocam previously and it is TS friendly. Only problem I experienced was very slow refresh rates. Directshow through explorer gives 25fps+ at 640x480 yet frodocam looked more like about 10fps (using a USB2.0 colour webcam with night vision)
                      Could direct show not be built into CF to allow display of cams natively.
                      My Nissan 200SX @ Silverstone
                      NOW SADLY WRITTEN OFF!
                      My Car's spec list + pics
                      Stealth CarPC fab'ing...
                        a Centrafuse webcam plugin could easily be built with my SDK, which will be available after 1.5 is released...
                        for all the programmers out there here is the API...
                        http://www.centrafuse.com/api
                        note: mainly check out the CFPlugin class... it is what will be used to create plugins...
                        david
                          You n00bs!! Just kidding...
                          Nullsoft (Streaming|S as in Soft) Video will record from a web cam to a file. It is open sorce too so you should be able to write some code to embed it into CF.
                          And if you have your cell phone internet dialup working, then this software will stream your web cam via shoutcast to a winamp client.
                          http://www.nullsoft.com/nsv/
                          download the NVS tools... http://www.nullsoft.com/nsv/nsvtools-setup.exe
                          after you install, open NVS Live Capture > chose your web cam in the Devises drop down > then goto File > Set capture destination > pick "File". It will save it in NVS format that can be played back with Winamp
                          ( www.winamp.com )
                          To stream your web cam you will need to down load the ShoutCast DNAS Server.You can run the server software from your home PC if you always have a way to know the ip address, i.e. the no-ip.com trick or static
                          I have not tryed this and there could be port issues streaming over a GPRS provider. shoutcast uses port 8000 and 8001 by default but can be adjusted.
                          let me know if you have questions and I will try to help.
                          now I am just going to have to go try this and see if I can get it to work while driving on the highway.
                          Randell Kelly
                            Hmmmmm... Shoutcast through phone over Internet .....
                            So, the cop thats beatin the crap out of me will be global before he gets back in his car ???
                            GitDafukOutaHere .... too cool
                            all I want is a USB flash drive with the data, actually 2( 1 for me - 1 for evidence )
                              Here's another thought .... I'm baaaaad tonight
                              Have a Forum for people on dates with " Dash Cams "
                              shoutcasting to all of everyone and in between...
